Question about angular muon flux
In summary: then angular muons have higher intensity than vertical, but this is not always the case when ##\phi## is not a whole number.
safinenko
Hi,
The Gaisser parametrization is something like:
[tex]\Phi_0(E,\theta)=AE^{-\gamma}\left[ \frac{1}{1+1.1E\cos(\theta)/E_{\pi}}+\frac{0.054}{1+1.1E\cos(\theta)/E_K} \right] [/tex]
where [tex]A,\gamma,E_{\pi},E_K [/tex] are constants. My question is: Is this saying that at higher zenith angles the flux of muons is stronger? Is there a reason for this?
Also, would this say that the intensity would be higher at an angle than at vertical for muons crossing the same opacity(=distance)?
Any input would be appreciated.
Thank you,
Safinenko
The flight length is shorter, so less muons decay (or get absorbed) before they reach the ground.
Why?
Hi, thank you for your input.
From what I have always understood, [itex]\theta[/itex] in the function was the zenith angle (angle from vertical). For example, here on top of page 3 the angle is defined from the vertical. So for [itex]\theta=0[/itex], [itex] E [/itex] in the fraction is multiplied by 1; for [itex]\theta=60[/itex], [itex] E [/itex] is effectively divided by half. So this leads me to think that angular muons have higher intensity than vertical. But obviously the distance muons travel vertically is shorter than at an angle!
Basically, this is the part that I am confused about.
Safinenko
The division by 2 indicates that the flight length doubled - you need twice the energy to counter this with time dilation. Therefore, E cos(θ) is a measure for the time the muon has to survive (in its own frame) to reach the ground.
No. If you want to make this comparison, compare muons with fixed energy.
In addition, take the solid angle into account: There is more solid angle between 79° and 80° compared to the region between 0° and 1° (as measured from the vertical axis).
If you want to take ##\phi## into account:
$$\Phi_0(E,\theta,\phi) =sin (\theta) \Phi_0(E,\theta)$$
Related to Question about angular muon flux
1. What is angular muon flux?
Angular muon flux is the measurement of the number of muons that pass through a specific area over time, taking into account the direction they are traveling in relation to the area. It is an important measurement in particle physics and can provide information about the nature of cosmic rays and other high-energy particles.
2. How is angular muon flux measured?
Angular muon flux is typically measured using specialized detectors such as scintillators or Cherenkov detectors. These detectors are able to detect the passage of muons and determine their direction of travel, which can then be used to calculate the angular muon flux.
3. What factors can affect angular muon flux?
There are several factors that can affect angular muon flux, including the elevation of the measurement location, the type and thickness of the materials in the detector, and the energy of the muons themselves. Additionally, variations in the Earth's magnetic field and the presence of other high-energy particles can also impact the measurement.
4. Why is angular muon flux important in scientific research?
Angular muon flux is important in scientific research because it can provide valuable information about the properties of high-energy particles and their interactions. This can help in understanding the nature of cosmic rays, as well as in the development of new technologies and advancements in particle physics.
5. How is angular muon flux used in practical applications?
Angular muon flux has practical applications in fields such as geology and archaeology. By measuring the flux in different locations, scientists can gain insights into the composition of the Earth's crust and the presence of mineral deposits. It can also be used in imaging techniques to detect hidden structures or voids in archaeological sites.
  • Calculus
