Question about axiom of regularity
In summary, the conversation discusses the axiom of regularity and its proof that a set cannot be an element of itself. This is demonstrated by considering the cases of S={S} and S={S,b}. The application of the axiom of regularity to S={A} shows that A={A,b} is false, as it leads to a contradiction. Therefore, there is no need to show that S and other elements, such as b or c, are disjoint.
Ling Min Hao
It has been stated that in axiom of regularity , a set cannot be an element of itself and there is a proof for which S={S} . I can understand his proof since S is the only element and hence its method of proof is viable here . But , what if I change the question to S= {S,b} ( it is a set which contain itself with another element , b) . How can we prove from here that every set cannot be an element of itself by using the axiom of regularity?
Hi, I don't know if can help but we are here also to discuss, so if you can prove (with your argument) that ##S=\{S\}## and ##b=\{b\}## separately, then ##S\cup b = \{S\}\cup\{b\}=\{\{S\},\{b\}\}=\{S,b\}## and not ##S##.
Likes Ling Min Hao
The axiom of regularity says that every non-empty set ##S## has an element ##b## such that ##S\cap b =\varnothing##.
If there was a set ##S## such that ##S\in S## (which covers both cases ##S=\{S\}## and ##S=\{S,b\}##), then consider the set ##\{S\}##. Since ##S\in S##, we have ##\{S\}\cap S =\{S\}\neq\varnothing##, which contradicts the axiom.
Yes it does show that contradiction occurs when S= {S} , what you show is the condition when S is the only element in the set S.What if there is another element b in the set S such that S={S,b}, does it hold true that S is not an element of S ?
So what you meant is if S={S} is a false statement , it means that S= { S,b} is a false statement too due to S is not an element of S from S={S}?
##S=\{S,b\}## is not false because ##S=\{S\}## is false, but because it contradicts the axiom of regularity, which doesn't say just that ##S\neq\{S\}##. See my previous post.
Perhaps it is easier to see this if we rename the sets: Assume that ##A=\{A,b\}##. Put ##S=\{A\}##. ##S## has only one element: ##A##. But ##S\cap A=\{A\}\cap\{A,b\}=\{A\}\neq \varnothing##. Hence, the nonempty set ##S## has no element which is disjoint from ##S##. This contradicts the axiom of regularity. Hence ##A=\{A,b\}## is false.
Likes Ssnow
From what you do , it still only show that
S = {A} is false . Yes, contradiction did occur on the side of S = {A} , but this is the case when A is the only element of S , but what if S = {A,c} ? Surely S won't be able to disjoint with A now but it is possible that S and c are disjoint . According to axiom of regularity , a set is true if at least one element is disjoint from the set . If S is disjoint with c , then the set S should hold the axiom of regularity right ? Now the problem is , how do we show that S and c are not disjoint so that it contradicts with axiom of regularity ?
Correct me if I am wrong
##S## is defined as ##\{A\}##. For any set ##A##, there exists a set ##\{A\}##, which we here call ##S##, so ##S=\{A\}## cannot be false. What is false is ##A=\{A,b\}##, because then, we will get a contradiction if we apply the axiom of regularity to ##S=\{A\}##. By the axiom, ##S##, which is nonempty, must contain an element disjoint from ##S##. Since ##A## is the only element in ##S##, this means that ##S\cap A=\varnothing##, but ##S\cap A = \{A\}##, which is a contradiction. The only way out of this contradiction is then that the assumption ##A=\{A,b\}## is false.
Notice that the axiom of regularity is applied to ##S=\{A\}##, not to ##A=\{A,b\}##. Therefore, there is no need to show that ##S## and ##b## or ##S## and ##c## etc. are disjoint.
Okay , basically i understand the logic behind it . I just have one more question to clear it out .
Can we define a set ourselves like S={A} so that we can imply that A={A,b} is false by using the axiom of regularity? I mean , does mathematics allow us to define something , then we prove something based on what we defined? Thanks anyway for spending your time on my problem.
Yes, in this case we can. The Pairing Axiom, one of the Zermelo-Fraenkel (ZF) axioms, says that to any sets ##a## and ##b##, there exists a set ##\{a,b\}##. If we apply this with ##a=b=A##, we see that there exists a set ##\{A,A\}=\{A\}##, which we may call ##S## if we want to.
(As the Wikipedia article shows, the pairing axiom is actually derivable from the other axioms in ZF.)
Likes Ling Min Hao
Finally I understand your method through axiom of pairing!
But if I want to say given A={A} , and it is shown that A is not an element of A from axiom of regularity , can I imply that since A is not element of A , the statement A={A,b} is false as well ?
Using the axiom of regularity, we can prove both ##A\neq\{A\}## and ##A\neq\{A,b\}## for all ##A## and ##b##.
Perhaps you mean this:
Can we, without using the axiom of regularity, prove that ##A\neq\{A\}## for all ##A## implies ##A\neq\{A,b\}## for all ##A## and ##b##?
I am not sure, but I don't think so. Anyone who knows?
I mean , if we proved that A is not an element of set A from axiom of regularity , does this result implies that A is not an element of the set A={A,b} too ?
Well, if ##A\notin A##, then we cannot have ##A=\{A,b\}##, because then ##A\in\{A,b\}##, that is: ##A\in A##.
Likes Ling Min Hao
But the result of "A is not an element of A " is shown from A = { A}, can this result be applied to any other case like A = {A,b} since the result of A is not element of A was based on A ={A}
Ling Min Hao said:
But the result of "A is not an element of A " is shown from A = { A}.
No ##A\notin A## is showed by applying the axiom of regularity to the set ##S=\{A\}##. ##A \neq \{A\}## can then be considered as a consequence of ##A\notin A##, and ##A\neq \{A,b\}## is also a consequence of ##A\notin A##.
Oh okay thanks for spending your time explaining it to me .
Related to Question about axiom of regularity
Question 1: What is the axiom of regularity?
The axiom of regularity, also known as the axiom of foundation, is a fundamental principle in set theory which states that every non-empty set must contain an element that is disjoint from the set itself. In other words, a set cannot be a member of itself.
Question 2: Why is the axiom of regularity important?
The axiom of regularity is important because it helps to avoid paradoxes in set theory, such as the Russell's paradox. It also ensures that sets are well-defined and allows for the construction of the cumulative hierarchy of sets.
Question 3: How does the axiom of regularity relate to the Zermelo-Fraenkel set theory?
The axiom of regularity is one of the axioms in the Zermelo-Fraenkel set theory, which is a foundational system for modern mathematics. This axiom is used to define the membership relation between sets and is essential for proving many theorems in set theory.
Question 4: Are there any alternatives to the axiom of regularity?
Yes, there is an alternative axiom called the anti-foundation axiom, which was proposed by Peter Aczel in the 1980s. This axiom allows for the existence of certain sets that violate the axiom of regularity, but it is not widely accepted in the mathematical community.
Question 5: Can the axiom of regularity be proven?
No, the axiom of regularity cannot be proven. It is an assumption or principle that is accepted as true without proof in order to build a consistent mathematical system. However, it can be shown that assuming the axiom of regularity leads to a consistent set theory.
