Question About Breaking Bonds in Crystal Lattices
The discussion centers on understanding the bond dissociation energy of compounds like silicon dioxide (SiO2) and aluminum oxide (Al2O3) when embedded in a crystal lattice versus their isolated forms. It highlights that bond dissociation energy typically refers to interactions between two atoms rather than the entire compound, complicating calculations in a lattice context. The energy required to remove an atom from a lattice is influenced by the surrounding atoms, necessitating a comprehensive analysis of the lattice structure. The conversation also clarifies misconceptions about enthalpy of formation and dissociation, emphasizing that these concepts are not directly interchangeable. Overall, the complexities of bonding in crystal lattices versus isolated molecules are crucial for accurate energy calculations.
NullusSum
TL;DR Summary
How do we calculate the bond dissociation energy of compounds in crystal lattices?
I am trying to understand how certain endothermic reactions work as a layman. I found the idea of reducing a rock to separate atoms fascinating, like what you would see in a comic book. However, I struggled to wrap my head around what that process would be like. I did some preliminary research, so I hope I was able to frame the question appropriately.
Question:​
How does the bond dissociation energy of compounds like silicon dioxide (SiO##_2##) and aluminum oxide (Al##_2##O##_3##) differ when they are embedded in a crystal lattice, such as in granite, compared to their isolated molecular forms? What additional interactions (e.g., lattice energy, covalent/ionic bonding) need to be considered when calculating the energy required to break these bonds in the lattice context?
Chemistry news on Phys.org
Broadly speaking there is no such thing as a "bond dissociation energy of a compound". Bond energy typically refers to bond between two atoms (they can be part of something larger, each atom can be bonded to more than one other atom). We sometimes write more complicated compounds in the oxide form (like Na2O⋅SiO2 instead of Na2SiO3), but that's mostly notational trick (it does reflect some underlying chemical properties of atoms involved, but doesn't mean "compound is a mixture of oxides"). There are some compounds in which it is possible to "show" separate molecules (and we can calculate energy of forces keeping them together), but these are not very common (and often classifying them as "compounds" blurs the difference between a compound and a mixture).
That being said for every atom energy required to remove it from the lattice is a sum of interactions with all surrounding atoms, so it doesn't matter much if you want to remove Si from SiO2 or Na2SiO3 - calculation will follow the same general principles.
What you ask about can be defined through the process "remove atoms, then create a compound out of them" (that's what the Hess's law is about) - but I don't remember seeing it used in this sense (even if it could be potentially useful in some contexts).
Likes Lord Jestocost and NullusSum
Thank you for the detailed answer. My presumption was that because a compound has an enthalpy of formation, it must also have a specific enthalpy of dissociation. Based on your answer, this seems to be an erroneous way of thinking.
So, if we took a simple SiO##_2## molecule, where the Si atom is covalenty bonded to two O atoms (O=Si=O), would the energy to remove the Si atom be approximately the dissociation energy of an O-Si bond (~799.6 kJ/mol) multiplied by 2? And if SiO##_2## is a compound in a lattice, would we have to take it a step further and identity every other atom bonded to the Si and O atoms by analyzing the lattice itself?
It is not erroneous as such, you can define this number and calculate its value in a strict way. Problem is you were freely jumping between bonding of atoms and "bonding" of molecules, as if they were the same thing. Thermochemically they can be definitely seen as analogous, but atoms are well defined in the context of a lattice, while "molecules" are not (see below).
Multiplied by 4 (every Si atom has four bonds with oxygens), but more or less - yes.
Thing is in the lattice Si is actually in the center of a tetrahedron, surrounded by four oxygen atoms, so while it has four bonds to oxygens, there are no double bonds involved (even if O=Si=O seems to be suggesting it). No SiO2 molecules there.
Compounds with separate molecules are abundant. All gases, and most liquids and solids that are capable of evaporating at low temperature.
There are different zero points of enthalpy.
Enthalpy of formation is forming solid SiO2 lattice out of elemental Si - which is a solid lattice full of Si-Si bonds - and elemental O, which is gas of O2 molecules containing O=O double bonds.
"Dissociating" the SiO2 lattice sounds like you want to dissociate the lattice into Si atoms and O atoms.
Take simple CO2 molecule. In O=C=O, both oxygens and both C=O double bonds are initially equal.
You might dissociate it into C and two O atoms, splitting both bonds and divide the total equally. That would give you one value.
Or you could dissociate just one O and leave CO molecule behind. You would get a different value for C=O bond strength.
Which of these two are you regarding as the dissociation energy of C=O bond.
Lattice energy?
It is trivial to split CO2 lattice into CO2 molecules. Just let it evaporate at -78 C, and measure the latent heat of evaporation.
I think the latent heat of evaporation is not yet the pure potential energy of lattice bonds because you have to account for the total thermal motion energy of CO2 lattice versus the total thermal motion energy of gaseous CO2 (translations, rotations, vibrations).
But a CO2 molecule in a lattice has a lot of van der Waals bonds. How do you define and measure the energy of each of them? Many of them are distinct. Solid CO2 lattice is low symmetry because it is trigonal.
As an alternative to splitting the lattice into molecules by evaporating (and then optionally into atoms by dissociating the molecules), you might split the lattice into lattices by cracking it. Just measure the work stored into creating the crack surfaces (as opposed to any dissipated into heat or by making crystal defects inside the shards), and compare the energy that goes into cracking the crystal in different directions. You can then compare the energy with the count and type of bonds that were broken and left dangling across the crack surface.
Can you define the dissociation energy of all distinct bond types by analyzing crack energy in different directions?
Compared to CO2, SiO2 is messy. At its boiling point, you have an appreciable amount of SiO2 molecules, but also appreciable amounts of SiO and O2 molecules and O atoms in the mix.
That's not what I referred to. Sure, if we put aside ionic solids and infinite lattices what we are left with are compounds that in bulk are a collection of molecules. But what about things like hydrates? These are basically compounds made of separate, individual molecules combined in a stoichiometric ratio. Methane hydrate for example doesn't decompose into atoms, it decomposes cleanly into methane and water, giving well defined "bonding energy" between constituting molecules.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
