Question about calculating work done
In summary, the conversation discusses the relationship between work and energy, and how pushing against a wall does not count as work because there is no motion. However, energy is still being expended and some argue that this should be considered as work being done. The concept of efficiency is also brought up, where energy in does not always equal work out due to losses.
mahaju
Hi
We all know that work done corresponds to energy used and calculated as force*distance
So if we are pushing against a wall, it does not count as work done, as there is no motion
However, aren't we still wasting energy when we are pushing against a wall? Since a certain amount of energy is being expended shouldn't it count as work being done?
For example, if we pass current through a resistor, there is no motion, still energy is used up as heat for the resistor. Shouldn't this energy expended be counted as some equivalent work being done?
Thanks
mahaju said:
Hi
Thanks
SHort answer - NO.
Work is Force*displacement [dot product of the two vectors] The dot product means that if the two vectors [force and displacement] at perpendicular, then no Work is done.
Note that if you swing a 10kg mass in a circle, the force you apply [centripetal Force] is at all times perpendicular to the motion - especially if you use a string - so no Work is done there either. You will certainly get tired, but the circling mass will not gain Kinetic Energy: is travels at constant speed in a circle.
Many people go to work every morning, then come home every evening, but, depending on their field of employment, may not do any Work at all - in the sense that we define it in Physics.
Notice that I called it Work, not work [capital letter].
so we should say that work requires energy, but use of energy does not always imply work
right?
Mechanical work is not the only way to expend energy, but your muscles are probably doing work. They are still contracting (so the cells are moving) and they are creating heat which is moving particles.
I think that in modern physics the idea of energy trumps the idea of work. Usually "mechanical work" is what the macroscopic [itex]\int F\cdot\vec{dx}[/itex] work is called. At a molecular and atomic level that definition becomes meaningless.
right?
If you define Work as macroscopic mechanical work (which is how my profs use it) then you are correct. I think the use of work to define energy is a historical artifact as well as a pedagogical tool. But I may be wrong.
right?
I note you have not referred to Work in your statement, merely work - which has far reaching "general-population" implications.
Remember; Work is ours, and has a very specific interpretation.
Work is spelled with a lower case "w", not Work; as this is a physics forum, I would assume most of the posters here know that when talking about work, the physics definition is implied.
mahaju said:
Hi
I believe Work represents the energy that is transferred through distance,not the energy is used.
In the case of pushing a wall although you use energy...you don't transfer energy to the wall hence you don't do Work.
The Work is differentiated from energy expenditure by the factor of efficiency(e=W/E).In wall pushing you have zero efficiency.
Thanks to everyone for the informative replys
Work is being done but not on the wall.The work is internal and due to the actions required of the muscles in order to do the pushing.
right?
Correct. Energy in doesn't usually equal work out due to losses: it is always less. You've just discovered the concept of efficiency.
FAQ: Question about calculating work done
How do you calculate work done?
To calculate work done, you need to multiply the force applied by the distance moved in the direction of the force. The formula for work done is W = F x d, where W is work done, F is force, and d is distance.
What units are used to measure work done?
Work done is typically measured in joules (J) which is equivalent to a force of 1 newton (N) acting over a distance of 1 meter (m). However, other units such as foot-pounds (ft-lb) or kilogram-force meters (kgf-m) can also be used.
Can work done be negative?
Yes, work done can be negative. This happens when the force and direction of motion are in opposite directions. In this case, the work done is considered to be negative as the force is acting against the direction of motion.
How does work done relate to energy?
Work done and energy are closely related. The work-energy principle states that the work done on an object is equal to the change in its kinetic energy. This means that when work is done, energy is either transferred to or from the object.
What are some real-life examples of work done?
Some real-life examples of work done include lifting weights, pushing a car, and climbing stairs. In these situations, a force is applied to an object and it moves a certain distance, resulting in work being done. Other examples include using a pencil to write, using a hammer to drive a nail, and using a bike to pedal up a hill.
