Question about capacitance matrix
In summary: Yes, we agree that it makes sense to calculate the capacitance between the pairs (1A,1B) and (2A,2B).
mnb96
715
Hello,
suppose I have four conductors (1,2,3,4) and I know their mutual capacitances cij where i,j∈{1,2,3,4}. Note that the quantities cij are essentially the elements of the capacitance matrix of this system.
Now, if I apply a voltage to two conductors and leave the other two grounded (e.g. V1=V2=1 and V3=V4=0), I would like to know the capacitance between the two pairs of conductors (1,2) and (3,4).
Is it possible to derive this quantity from the sole knowledge of the capacitance matrix? If so, how?
Assuming the medium between the conductors is linear, the capacitance is only a function of the geometry and the material properties (dielectric constant) not the applied voltages. The capacitance matrix simply relates the applied voltages to the charges on the conductors.
EDIT: my answer assumes you are simply setting voltages of the conductors. Is this all you are doing, or are you adding conductors (such as wires) in order to electrically connect the conductors?
Jason
The physicist answer: Go measure it!
Thanks for the answer, jasonRF.
You correctly understood that all I am doing is applying voltages to the conductors: I am not adding wires to connect them. In this case, as you said, assuming the medium is linear then the capacitance is only a function of the geometry and the material. Fine, but is seems to me that the question remains: if we know the full capacitance matrix of 1,2,3,4, is it possible to directly deduce the capacitance between the pairs (1,2) and (3,4)?
From the last part of your answer, I am inclined to guess that, if the medium is not linear, then the answer is no.
I guess I don't understand what you mean by
mnb96 said:
... the capacitance between the pairs (1,2) and (3,4)
Could you explain?
Could you explain?
Yes. I would like to consider the conductors 1,2 as a single entity (analogous to a capacitor plate) and the conductors 3,4 as another entity (analogous to the other capacitor plate) and calculate the capacitance between them.
The only thing I have information about is the mutual capacitances between each of the four conductors.
It's tempting to consider that the capacitance could be the sum of the obvious capacitances.
However, if you draw a parallel plate capacitor and insert a much larger plate between them, the tentative theory of summing two capacitances looks like not holding here because of the shielding effect of that middle plate. So I'd generalise this to say there is no general method you can apply to that limited data set.
https://www.physicsforums.com/attachments/110502.gif
If you want to consider 1,2 as a single entity, what does it mean for 1,2 to have charge +Q and 3,4 to have charge -Q? Are 1 and 2 somehow free to exchange charge (without being connected!)? I still don't understand the question ... I will hang back and let others continue to answer.
Likes Delta2
Maybe I did not manage in first place to formulate my question properly.
Let's try with one example which slightly differs from the original post: Suppose we have a very simple circuit: one battery whose terminals are connected to the plates 1,2 of a capacitor (see figure at this link). Now, imagine that I take a pair of scissors and I make a straight cut on both plates. Plate 1 has now been split into two smaller plates (let's call them 1A and 1B). Analogously, plate 2 has been split into 2A and 2B. Note that we have now four plates.
I also assume that the two wires that connect the terminals of the battery to the plates bifurcate into 1A-1B and 2A-2B.
Now, do we agree that it makes sense to calculate the capacitance between the pairs (1A,1B) and (2A,2B). And do we agree that this capacitance will be similar (but not equal to) the capacitance between 1-2 (the original plates without the cuts)?
If yes, then we can continue the discussion, otherwise my intuition is wrong.
Yep, I agree. Now I understand - since your battery wires are bifurcated the 1A and 1B are electrically connected. Perhaps it didn't matter, but I couldn't wrap my brain around the question any other way.
Anyway, if 1 and 2 in your original question are electrically connected (so can exchange charges) to form (1,2), and likewise for (3,4), then I would approach the problem as follows. First consider the 4 conductor case, for which the charges are given by,
[tex]
\begin{eqnarray*}
Q_1 & = & C_{12}(V_1-V_2) + C_{13}(V_1-V_3) + C_{14}(V_1-V_4) \\
Q_2 & = & C_{12}(V_2-V_1) + C_{23}(V_2-V_3) + C_{24}(V_2-V_4) \\
Q_3 & = & C_{13}(V_3-V_1) + C_{23}(V_3-V_2) + C_{34}(V_3-V_4) \\
Q_4 & = & C_{14}(V_4-V_1) + C_{24}(V_4-V_2) + C_{34}(V_4-V_3)
\end{eqnarray*}
[/tex]
Here [itex]C_{12}[/itex] is the capacitance between 1 and 2, etc. Note that I have used the fact that [itex]C_{12}=C_{21}[/itex], etc. This formulation follows that in "Field and Wave Electromagnetics" by Cheng, but many many books cover this stuff.
Setting [itex]V_1=V_2=V^\prime[/itex] and [itex]V_3=V_4=0[/itex] I get,
[tex]
\begin{eqnarray*}
Q_1 & = & (C_{12}+ C_{13})V^\prime \\
Q_2 & = & (C_{23}+ C_{24})V^\prime \\
Q_3 & = & -(C_{13}+ C_{23})V^\prime \\
Q_4 & = & -(C_{14}+ C_{24})V^\prime
\end{eqnarray*}
[/tex]
Since the charge on (1,2) is simply [itex]Q^\prime=Q_1+Q_2[/itex] I get
[tex]
\begin{eqnarray*}
Q^\prime & = & (C_{12}+ C_{13}+C_{23}+ C_{24})V^\prime \\
& \equiv & C^\prime V^\prime
\end{eqnarray*}
[/tex]
So I get that the capacitance of the new system is [itex]C^\prime = C_{12}+ C_{13}+C_{23}+ C_{24}[/itex].
I also see that that [itex]Q_3+Q_4 = -Q^\prime[/itex], as we expect for a capacitor.
Does my explanation make sense, or did I do something screwy?
EDIT: if you draw a picture of 4 "blobs" with capacitors between them and add shorts to connect (1,2) and (3,4) the picture will show you 4 capacitors in parallel, which should add just like the formula I derived. So this seems plausible.Jason
Likes mnb96
I just took another look at my post and see a typo: it should be
[tex]
\begin{eqnarray}
Q_1 & = & (C_{13}+C_{14}) V^\prime \\
C^\prime & = &C_{13}+C_{14} + C_{23}+C_{24}
\end{eqnarray}
[/tex]
Also, I didn't specify that I was considering a scenario where the 4 conductors were the only things in the universe. Often these kinds of problems are modeled by essentially assuming our 4 conductors are inside a grounded spherical shell of infinite radius; if we do this then the starting equations are
[tex]
\begin{eqnarray*}
Q_1 & = & C_{01} V_1 + C_{12}(V_1-V_2) + C_{13}(V_1-V_3) + C_{14}(V_1-V_4) \\
Q_2 & = & C_{02} V_2 +C_{12}(V_2-V_1) + C_{23}(V_2-V_3) + C_{24}(V_2-V_4) \\
Q_3 & = & C_{03} V_3 +C_{13}(V_3-V_1) + C_{23}(V_3-V_2) + C_{34}(V_3-V_4) \\
Q_4 & = & C_{04} V_4 +C_{14}(V_4-V_1) + C_{24}(V_4-V_2) + C_{34}(V_4-V_3)
\end{eqnarray*}
[/tex]
where ##C_{01}## is the capacitance of conductor 1 with respect to ground (which as at infinity) .
Jason
Likes mnb96
Thanks jasonRF!
Your explanation makes sense to me and it seems to be what I was looking for.
Now I just need to spend some time to make sure I fully understood the reasoning. I am now reading the chapter on capacitors of "Field and Wave Electromagnetics" by Cheng.
I will post again in the next days.
By the way, are those four additional terms that you introduced in the last post the self-capacitances of the four conductors?
Yes, the addition terms are self-capacitances - or the capacitances with respect to ground. I should probably have used the notation [itex]C_{11}[/itex] instead of [itex]C_{01}[/itex].
jason
Hello,
after working on this problem, I would have an additional question related to it.
Let's consider a similar scenario where we have four conductors such that V1=V2=1 and V3=0 (as in the original post), but now the 4th conductors is "floating" instead of being grounded (i.e. it is physically disconnected from the rest of the circuit).
If we consider the following equations:
jasonRF said:
[tex]
\begin{eqnarray*}
\end{eqnarray*}
[/tex]
Jason
How do we treat floating conductors?
Should we simply set Ci4=C4i=0 in the above matrix?
Related to Question about capacitance matrix
1. What is a capacitance matrix?
A capacitance matrix is a mathematical representation of the relationship between the voltages and charges across different components of an electrical circuit. It is used to calculate the total capacitance of a system and can help determine the behavior of the circuit when subjected to varying voltages and frequencies.
2. How is a capacitance matrix calculated?
A capacitance matrix is calculated by first determining the capacitance of each individual component in the circuit. This can be done using the formula C = Q/V, where C is the capacitance, Q is the charge, and V is the voltage. The individual capacitance values are then arranged in a matrix, with each element representing the capacitance between two components. The matrix is then manipulated using mathematical operations to determine the overall capacitance of the system.
3. What are the applications of a capacitance matrix?
A capacitance matrix is commonly used in the design and analysis of electrical circuits, particularly in the field of electronics and telecommunications. It can also be used in the design of capacitive sensors, touchscreens, and other devices that utilize the principles of capacitance. Additionally, capacitance matrices are used in the study of electromagnetism and in the development of computer models for complex circuits.
4. How does a capacitance matrix differ from an impedance matrix?
While a capacitance matrix represents the relationship between voltages and charges in a circuit, an impedance matrix represents the relationship between voltages and currents. In other words, a capacitance matrix is specific to capacitive elements in a circuit, while an impedance matrix takes into account both capacitive and inductive elements. Additionally, the units for a capacitance matrix are in farads, while the units for an impedance matrix are in ohms.
5. Can a capacitance matrix be used for circuits with non-linear components?
No, a capacitance matrix is only applicable to linear circuits where the relationship between voltage and current is constant. Non-linear components, such as diodes and transistors, have varying relationships between voltage and current and therefore cannot be accurately represented using a capacitance matrix. In such cases, more complex mathematical models are required to analyze the circuit's behavior.
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
  • Classical Physics
