Question about centrifugal force and Bernoulli's law.
In summary, the conversation discusses the idea of maintaining gas at high pressure for propulsion purposes. However, containing the gas at high pressure would require a thick walled tank, which would add too much mass. The solution proposed is to move the gas at high speed within the tank, using the Bernoulli principle to reduce pressure on the tank walls. However, there is a debate about whether this would actually work, as the pressure may increase due to centrifugal force. One possible solution is to have a tank with long straight portions on either side and curved portions at the top and bottom, with only the top and bottom needing to be thick walled. There is also a discussion about the effects of centrifugal
RGClark
86
What I want to do is maintain a gas at very high pressure and temperature for propulsion purposes. The problem is containing a gas at high pressure requires a thick walled tank, and the resulting mass would obviate the advantage of having the gas at high pressure.
So what I'm considering is moving the gas at high speed within the tank. By the Bernoulli principle the tank should see the pressure on its walls as much less.
However, if the gas is moving around a cylindrical tank or a toroidal tank, then by centrifugal force that would seem to indicate it should increase the pressure(!)
Which one wins out?
Here's one possible way to address this problem. You could have the tank consist of long straight portions on either side but be curved at the top and bottom. Then you would only have to keep the portions at the top and bottom to be thick walled to maintain the pressure increase due to centrifugal force. If the straight portions are much longer than the curved parts at top and bottom, you could get a large volume without having to add too much to the tank mass.
Bob Clark
This won't work. The way Bernoulli's law works is that it has to be applied along a streamline. Then an increase in speed along that streamline results in a reduction in the pressure.
What I was envisioning is that if you have a flow at steady speed and it flows horizontally over a surface, while maintaining the same constant speed, then the pressure applied to the surface will be less than the pressure far from that surface. This is not how Bernoulli works. It only applies when the velocity is different between two points in the flow.
Bob Clark
Don't envisage that, because neither it works as you said. When you are close to the surface, the effect of viscosity is non negligible at all, even if your external flow is extraordinarily fast. Close to the surface there would be the so-called Boundary Layer. Moreover, the pressure gradient ACROSS the Boundary Layer is negligible at first order, so the wall would feel the pressure of the external flow, which would be less than if the fluid is stagnant of course.
Bob Clark
The Bernoulli equation can be still applied to your system. Assume that the flow is steady. There is no radial component of velocity, but there is an azimutal component of value [tex]u_\theta=\Omega r[/tex] which increases with r (solid body rotation). The pressure force is counterbalanced with the centrifugal force, such that your new "Bernoulli" equation (which shows up after solving the N-S equations for your flow and it's independent of the Reynolds Number you use), it is:
[tex]P+\rho\frac{\Omega^2 r^2}{2}=Const[/tex]
if your vessel is closed and the rotation speed is small enough for considering incompressible flow, and you're looking far away from the upper and bottom walls. I'm very afraid the constant should be worked out from the transient regime. I mean, I cannot chose any vessel radial coordinate and set a pressure, because I don't know the pressure inside. If you put gas in the tank at rest at certain pressure, and begin to rotate it with rotation speed [tex]\Omega[/tex], the pressure inside will be modified and reordenated spatially until reaching the steady state described by the Bernoulli equation above.
The bottom line is that speeding up the gas flow does not change the energy of the gas molecules. If you confine those molecules withiin a container, they will exert the same average force per unit area on the container whether they are flowing (moving together with the same average energy) or not (moving randomly with the same average energy).
AM
AM
Wait I am not sure about that. Let's look at it from a reference frame attached to the vessel. The centrifugal force is definitely generating a gradient of pressure. It is a non-equilibrium situation. There is a gradient of a bulk magnitude inside the fluid. I think it definitely increases the pressure towards the vessel walls. Why not?.
You are right. I should have said:the same average pressure throughout the gas.
The centripetal force is provided by collisions with the walls of the container by the individual molecules (ie. pressure). Since the average energy of the molecules is the same, the pressure would be the same unless the number of molecules per unit volume is greater near the container wall, in which case the pressure on the walls would be greater. In any event, it would not be less than the pressure in a static situation, which was really my point. You cannot decrease the pressure by making the gas flow within the container.
AM
AM
Ok, it seems now I understand you. You mean that despites the pressure is non homogeneous, it's average keeps on being the same initial pressure, as well as the temperature (same average energy). I keep on not being very sure about that. I don't think the average energy remains the same. Where does the power introduced in the vessel because of the rotation go?. There is an external inflow of power into the system, it must be somewhere, and I think it must go to modify the thermodynamic state of the gas, even in the average. I don't think it has sense here to talk about energy in the average for the whole gas. There are small energies in the average, in differentials of r, but not in the whole vessel. With that I mean that we have to employ the Non Equilibrium Kinetic Theory (which by the way gives rise to the N-S equations and to the equation I posted above), because the collision dynamics are not in equilibrium in the whole, and one cannot define a total maxwellian distribution.
What one can do is to assume thin radial slices in which there The Local Equilibrium Hypothesis is almost valid, and do an average inside those thin slices. So I am not sure about your statement about having the same pressure on the average. Is there any way of showing it analitically?. This is an interesting problem...
If you make the gas flow you do not necessarily have to increase its energy. Bernouilli's principle after all is based on conservation of energy: if you speed up the gas flow (without adding energy), its pressure drops. I don't see the point of adding more energy to the gas if what you want to do is lower the pressure.
AM
FAQ: Question about centrifugal force and Bernoulli's law.
What is centrifugal force?
Centrifugal force is a fictitious force that appears to act on a body moving in a circular path. It is the outward force acting on an object that moves in a curved path, and it is caused by the object's inertia.
How is centrifugal force related to Bernoulli's law?
Centrifugal force is not directly related to Bernoulli's law, but it can be taken into account when applying Bernoulli's principle to a system. This is because Bernoulli's law is based on the conservation of energy, and centrifugal force is a type of energy.
Can centrifugal force and Bernoulli's law be used to explain the behavior of fluids?
Yes, both centrifugal force and Bernoulli's law can be used to explain the behavior of fluids. Bernoulli's law is commonly used to describe the pressure and speed of a fluid moving through a pipe, while centrifugal force can be used to explain the behavior of fluids in rotating systems.
Is centrifugal force a real force?
No, centrifugal force is a fictitious force. It only appears to exist because of the object's inertia, and it is not caused by any physical interaction between objects.
How can I calculate the centrifugal force in a system?
The formula for calculating centrifugal force is F = mω²r, where F is the centrifugal force, m is the mass of the object, ω is the angular velocity of the object, and r is the distance from the center of rotation. However, it is important to note that this formula only applies in circular motion and does not work in non-uniform motion.
