Question about Centripetal Force
In summary, the conversation discusses the application of centripetal force and friction in the context of a car turning and a block being dragged. It is mentioned that in force diagrams, the centripetal force is typically shown acting on the center of mass rather than the point of contact between the tires and the ground. It is also explained that in non-inertial frames, the force diagrams may look different. Additionally, the concept of reactive force and roll torque is discussed, as well as the relationship between vertical forces and roll torque. The conversation concludes with a clarification of the abbreviation CF, which stands for centripetal force.
Red_CCF
532
Hi
For a car making a turn, the friction between the tires causes the centripetal force, but how come in FBD I always see the centripetal force being drawn acting on the center of mass and not the point of contact between the wheels and the ground? Similarly, if I was dragging a pick of block, in the books (and in class) the FBD of the friction force was drawn to be acting on the center of mass and not the point of contact.
Thanks.
In animated diagrams, or in the case of some racing games or simulators, you can see force diagrams at the contact patches. There are inwards centripetal forces at the contact patches. There is an outwards reactive force to the net centripetal acceleration at the center of mass, and this results in an outwards roll torque.
Thanks for the response.
I didn't really understand where the outward reactive force applied to the CoM comes from and what is counteracting this roll torque?
The reactive force is not applied to the CoM, it's the reaction of the mass of the car in response to centripetal acceleration, and it can be considered to be acting at the CoM of the car. The Newton third law pair of forces here are the net centripetal force generated by the pavement onto the tires, with an equal and opposing outwards reactive force generated from the car's mass and applied through the tires to the pavement.
An opposing roll torque created by the imbalance of the vertical forces between the inside and outside tires and the pavement. The upwards force from the pavement on the outside tire is greater than the upwards force on the inside tire, and this produces the counteracting torque.
So if I draw a FBD of a car going around a circle in an inertial frame, I should have gravity acting down at the CG, a centripetal force at the tires pointing towards the inside of the circle, and two differing forces acting at the inside and outside tires with the outside being bigger? How would the FBD look if it was drawn from an non-inertial frame?
Thank you very much
FordRanger4x4 said:
frictional force will be on the tires facing opposite where the car wants to go. so if a car is turning left, the frictional force will be pointing left on the FBD. the CF is summed and shown on the FBD to be at the CM
Hi
What does CF stand for?
Thanks
Red_CCF said:
Hi
Thanks
centripetal force, sorry. hope this helps
FAQ: Question about Centripetal Force
What is centripetal force?
Centripetal force is the force that acts on an object moving in a circular path, directing it towards the center of the circle.
What is the difference between centripetal and centrifugal force?
Centripetal force pulls an object towards the center of a circle, while centrifugal force pushes an object away from the center. Centrifugal force is a reaction force to centripetal force.
What are some examples of centripetal force in everyday life?
Examples of centripetal force include the force exerted by a car's tires on the road while turning, the gravitational force that keeps planets in their orbits around the sun, and the tension force in a string that keeps a spinning object moving in a circular path.
How is centripetal force calculated?
The magnitude of centripetal force can be calculated using the formula F = mv²/r, where m is the mass of the object, v is its velocity, and r is the radius of the circular path.
How does centripetal force relate to Newton's laws of motion?
Centripetal force is a result of Newton's first law of motion, which states that an object in motion will continue in a straight line at a constant speed unless acted upon by a force. In circular motion, the centripetal force acts as an inward force to change the direction of the moving object and keep it in a circular path.
