Question about chlorine + water
  • Thread starter gamer87
  • Tags
    Water
In summary, the conversation discusses the use of 2.5% active chlorine in a product called sanitary water for cleaning in Brazil. The person is concerned about the volatility of the chlorine and its potential to spread around the house and oxidize metals and other objects. They compare this to straight bleach, which has a higher concentration of hypochlorite and is known to be strong and caustic. The conversation also mentions the term "gray water" in the US, which refers to used household water. The conversation ends with a note about previous discussions on the same topic and the difficulty in providing an answer that the person wants versus one that is correct.
gamer87
40
2.5% active chlorine + water is very volatile and spreads around the house oxidizing metals and other objects ?? here we use a product called sanitary water
Chemistry news on Phys.org
Is there a question in there?
  • Haha
Likes chemisttree
Straight bleach is around 8% hypochlorite so 2.5% is about a third of that. Yes, very strong and caustic too. pH 11-12! It will smell strongly of bleach and can oxidize metals given enough time with poor ventilation.
In the US, sanitary water is known as “gray water.”
Here in Brazil this product has 2.5% active chlorine and my family use it every day in bathroom cleaning for a few minutes the bottle is open so I thought this is volatile evaporates it spreads through the house and goes down depositing on metals, appliances electronics and DVD discs causing them to corrode?
You already have several threads on this same topic. It seems that since we do not give you an answer that you want, rather than one that is correct, we cannot help you.
Thread locked.
Likes chemisttree and berkeman
FAQ: Question about chlorine + water
What happens when chlorine is added to water?
When chlorine is added to water, it reacts with the water molecules to form hypochlorous acid and hydrochloric acid. This process is known as chlorination and it helps to disinfect the water by killing harmful bacteria and viruses.
Is it safe to drink water with chlorine?
Yes, it is generally safe to drink water with chlorine. The amount of chlorine added to drinking water is carefully regulated to ensure it is at a safe level for consumption. However, some people may be sensitive to chlorine and may prefer to use a water filter to remove it.
How does chlorine affect the taste and smell of water?
Chlorine can give water a slightly chemical taste and odor, similar to the smell of a swimming pool. This is because chlorine reacts with organic matter in the water to form compounds called chloramines. These compounds can affect the taste and smell of water, but they are not harmful.
Can chlorine in water be harmful to my health?
In small amounts, chlorine in water is not harmful to most people. However, exposure to high levels of chlorine can cause irritation to the skin, eyes, and respiratory system. It is important to follow the recommended guidelines for chlorine levels in drinking water to avoid potential health risks.
How is chlorine removed from water?
Chlorine can be removed from water through a process called dechlorination. This can be done through various methods such as using activated carbon filters, exposing the water to sunlight, or using chemical agents like sodium bisulfite. Water treatment plants also use dechlorination processes before releasing treated water into the environment.
