Question about Classical mechanics John R. Taylor
In summary, Taylor's advanced text on classical mechanics discusses an example of a non-holonomic system involving a hard rubber ball being rolled in a triangle on a flat surface. This example highlights the difference between holonomic and non-holonomic systems, with the latter having constraints on the motion that do not restrict the accessible configurations, but only the paths to them. This is demonstrated by the no-slipping condition in the ball rolling example, which cannot be written in the form of a constraint on the coordinates only.
HomogenousCow
737
213
In Taylor's advanced text on classical mechanics, he gives an example of a non-holonomic system, I find this part very strange.
He gives the example of a hard rubber ball being rolled in a triangle on a flat surface, the point is that if you take the ball out through the triangle and back to the initial position, the orientation of the ball will be different at the end.
I don't understand why that would make the system holonomic, if we treat the ball as a rigid body it would have 6 degrees of freedom, three numbers to specify its spatial position and three numbers to specify its orientation, it seems to me that only when we ignore the extended nature of the ball does the system become non-holonomic.
Here is one explanation:
Holonomic system is one in which the constraints on the coordinates are of the form
f(q_1, q_2, ...) = 0.
For example, mass point bound to a sphere of radius ##r## in space has constraint
x^2 + y^2 + z^2 = r^2,
and locally the condition
xdx + ydy + zdz = 0
has to be satisfied. The point has only two free degrees of freedom; for example, x and y. If we know displacements in these, the displacement in z can be calculated from the above equation.
The ball rolling without slipping is another kind of system, because the no-slipping condition cannot be written in the above way with coordinates only; the condition says that the velocity of the contact point on the ball is zero.
The constraint equation for such system will contain also the derivatives of the coordinates ##x,y,\varphi,\vartheta,\alpha##, and the local version will contain time differential ##dt##. There is no one definite relation between these 5 coordinates and no definite constraint on their changes; what will happen to them depends also on the angular velocity of the ball.
This means that although there is a constraint on the motion, one can make infinitesimal changes in four variables ##x,y,\varphi,\vartheta##, but these still do not determine the change in ##\alpha## ; the value of the latter depends on the path chosen for the change of the former four coordinates.
Here is another, presumably simpler way to understand non-holonomic system:
if the system has constraint on motion which does not restrict accessible configurations, only the paths to it, it is non-holonomic. The ball can get into any state ##x,y,\vartheta,\varphi,\alpha##, but the path cannot be arbitrary since it has to be such that no-slipping condition is satisfied.
Related to Question about Classical mechanics John R. Taylor
1. What is classical mechanics?
Classical mechanics is a branch of physics that deals with the motion of macroscopic objects, such as planets, cars, and baseballs. It is based on Newton's laws of motion and can accurately describe the behavior of objects at speeds much slower than the speed of light.
2. Who is John R. Taylor?
John R. Taylor is a physicist and author of the popular textbook "Classical Mechanics." He is also a professor emeritus at the University of Colorado Boulder, where he taught for over 40 years.
3. What are the main topics covered in "Classical Mechanics" by John R. Taylor?
The main topics covered in "Classical Mechanics" include kinematics, forces, energy, momentum, rotational motion, and oscillations. It also discusses key concepts such as conservation laws, the principle of least action, and Hamiltonian mechanics.
4. Is "Classical Mechanics" by John R. Taylor suitable for beginners?
While "Classical Mechanics" is a comprehensive textbook, it is written in a clear and accessible manner, making it suitable for beginners. It does not require prior knowledge of physics, but some mathematical background is helpful.
5. How is classical mechanics relevant in today's world?
Classical mechanics is still relevant in today's world as it forms the basis for many practical applications, such as designing bridges, buildings, and vehicles. It is also used in fields such as astronomy, engineering, and even sports science. Additionally, many modern theories in physics, such as quantum mechanics, are built upon the principles of classical mechanics.
  • Classical Physics
  • Mechanics
  • Classical Physics
  • Quantum Interpretations and Foundations
12K
