Question about concave mirrors
In summary: I was simply explaining the basic shape of a curved mirror and how it relates to the different equations for conic sections.In summary, concave mirrors are part of a sphere, but they can also be expressed as a parabola equation. However, this equation is just an approximation and not a perfect representation of the mirror's shape. This is because the shape of a curved mirror is a conic section rotated around an axis, and a parabolic mirror is just one type of conic section. Other mirrors can have more complex shapes, and even a parabolic mirror is not a perfect representation of a paraboloid. So while the parabola equation may be helpful in understanding the basic shape of a curved mirror, it is not always
bubblewrap
134
I read that concave mirrors are part of a sphere, and concave mirrors can also be expressed in a parabola equation, but a parabola equation is expressed as #4py=x^2# and a circle as #x^2+y^2=R^2#. So the two can't be the same right? Can someone please explain this? Thank you in advance :)
Science news on Phys.org
Right. Perhaps you mis-read one of them or perhaps there are two different kinds of mirrors. If only one is right which one do you think it would be?
Actually, concave isn't related to a particular shape. Concave just means hollowed inwards.
Are both the cases you mentioned hollowed inwards?
Good point
The basic shape of a curved mirror is a conic section rotated around an axis to form a surface. (A conic section being a slice of a cone at various angles) A parabolic mirror is shaped like parabola that has been rotated. This surface is called a paraboloid, specifically an elliptic paraboloid.
You can think of the mirror as a small portion of the very bottom of this shape.
Rotating other conic surfaces, such as ellipses, circles, and hyperbolas, yields a differently shaped surface for each. More complicated mirrors can have a very complex surface shape that isn't simply a rotated conic section. We even have adaptive optics in professional telescopes that actively change the shape of the mirror to compensate for the effect turbulence in the atmosphere has on incoming light.
Some links:
http://en.wikipedia.org/wiki/Conic_section
http://en.wikipedia.org/wiki/Parabolic_reflector
Likes bubblewrap
Drakkith, that certainly true but it is just your opinion that a mirror is automatically a parabolic surface? The point is not necessarily to reflect a point source to a focus, it's to enlarge what's being looked at. What reason does a hand-held bathroom mirror have to be parabolic? Is there a reason why spherical wouldn't work better? Also, why are you jumping in with a solution, right or wrong, when I'm trying to get the OP the think about it himself?
A small portion of a circle is pretty much indistinguishable from a (small portion of) a parabola. The posh way of showing this is to use a Taylor expansion of the circle equation. I give an elementary derivation in the thumbnail. A revolved parabola gives a paraboloid and a revolved circle gives a sphere. Hope this helps.
So when we say that a concave mirror is a parabola and a part of a sphere, its not actually a sphere but an approximation. And the property of the light crossing the center of the sphere and reflecting back to that point is also an approximation right?
That's right.
If you try and apply it to a paraboloid, then it is an approximation. But as long as it's only a small 'shallow' portion of the parabola, (and symmetrical about the axis of the parabola), the approximation isn't too bad.
No. I don't know why you would think that.
Related to Question about concave mirrors
1. What is a concave mirror?
A concave mirror is a type of curved mirror where the reflective surface is curved inwards, creating a bowl-like shape. It is also known as a converging mirror because it causes parallel rays of light to converge at a focal point.
2. How does a concave mirror form an image?
A concave mirror forms an image through the process of reflection. When light rays from an object strike the curved surface of the mirror, they reflect off at different angles, depending on their distance from the center of the mirror. This causes the light rays to converge and form an image at the focal point.
3. What is the difference between a concave and convex mirror?
The main difference between a concave and convex mirror is the shape of their reflective surfaces. A concave mirror curves inwards, while a convex mirror curves outwards. This results in different properties, such as the ability to form real or virtual images.
4. How is the focal length of a concave mirror determined?
The focal length of a concave mirror is determined by the distance between the mirror and its focal point. It is equal to half the radius of curvature of the mirror, which is the distance between the center of the mirror and its reflective surface.
5. What are some practical applications of concave mirrors?
Concave mirrors have many practical applications, including in telescopes, flashlights, and headlights. They are also used in makeup mirrors, solar cookers, and reflectors for satellite antennas. Concave mirrors are also used in medical equipment, such as dental and endoscopy mirrors.
  • Optics
  • Optics
