Question about conditions for Force Free Fields in plasma
In summary, the conversation discusses the conditions for a Free-Force field in the study of plasma stability and addresses a question regarding the curl of a vector in relation to the direction of the vector. It is noted that while the cross-product of two vectors is always orthogonal to the two vectors, the curl of a vector may have a component along the direction of the vector.
Clear Mind
38
My question is about Force Free fields in the study of plasma stability (in MHD regime): Consider an isolated ideal plasma in an equilibrium state (where the effect of selfgravity is negligible), from the Navier-Stokes equation we get that:
$$\vec{\nabla} P = \frac{1}{c} \vec{J} \times \vec{B}$$
Now, if ##P=const## and ##\vec{J}## (in MHD ##\vec{J}\propto\vec{\nabla}\times\vec{B}##) is parallel to ##\vec{B}##, we get that ##(\vec{\nabla} \times \vec{B}) \times \vec{B}=0##. Thus implies that:
$$(\vec{\nabla} \times \vec{B}) = \alpha(r) \vec{B}$$
That is the condition for a Free-Froce fields. So ... the question is, shouldn't be the curl of a vector always be orthogonal to the vector?
The cross-product is orthogonal to the two vectors, but the curl is not a proper cross-product. It can have a component along the direction of the vector. This is easy to see if you add a constant to B: its curl won't change, but you can change the direction of B arbitrarily.
Likes Clear Mind
Ok, i see! Many thanks for the help :D
Related to Question about conditions for Force Free Fields in plasma
1. What are force-free fields in plasma?
Force-free fields in plasma are magnetic fields that do not experience any external forces or pressure. This means that the plasma particles move along the magnetic field lines without any hindrance or resistance.
2. How are force-free fields created in a plasma?
Force-free fields can be created in a plasma through the process of magnetic reconnection, where oppositely directed magnetic field lines merge and release energy. This results in a force-free state where the plasma particles can freely move along the magnetic field lines.
3. What are the conditions required for force-free fields to exist in a plasma?
The two main conditions for force-free fields in plasma are that the plasma must be highly conducting and the plasma particles must have low inertia. This allows for the plasma to be easily influenced by the magnetic field and to move freely along the field lines without any significant resistance.
4. How are force-free fields important in plasma physics?
Force-free fields play a crucial role in many plasma phenomena, such as solar flares and coronal mass ejections. They also have practical applications, such as in magnetic confinement fusion devices, where force-free fields are used to contain and control the plasma.
5. Can force-free fields exist in other types of fluids besides plasma?
Yes, force-free fields can exist in other types of fluids, such as liquid metals and conducting liquids. However, the conditions for their existence may vary depending on the specific properties of the fluid. In general, force-free fields require a highly conductive medium and low inertia particles to exist.
  • Electromagnetism
  • Quantum Physics
  • Electromagnetism
