Question about converting propane vapor volume to liquid gallons
In summary: You would need to pump the car down to a lower pressure and then recover the vapor. However, if you are experiencing a lot of shink (a deviation from the industry's acceptable shrink rate of 2%), then it may be worth it to pump the car down to a lower pressure and then recover the vapor.
My05stang
Hello, I work for a propane company where i unload propane rail cars. I am trying to figure out how much propane is being shipped back to the refinery after I off load the rail car. We are experiencing a large amount of shink and the accountant want to get to the bottom of it. With propane the industry acceptable shrink is 2% and we are over 4% currently.
Depending on air temperature my cars range from 150 PSI summer to 70 PSI winter +\-. During the off load I pump the rail car dry of all liquid propane then revers the compressor and begin to recover the vapor. I typically draw the rail cars down to 40 PSI because at that point it gets difficult on the compressor and it begins to build up heat. Typical capacity of a rail cars is 34,000 gallons.
Here is my question... I will use today as my example. Rail car capacity was 34,010 gallons
propane temperature was 53 f.
Pressure was 95 psi when i began to recover vapor. I ran my compressor till pressure was down to 45 PSI
not sure if this is needed or not but specific gravity of the load was .501. Thats the liquid as stated on Bill of lading. correct me if I'm wrong its been a long time since all my propane training but I think Propane vapor is 1.5 specific gravity.
how much liquid propane was recovered from the car and how much was left inside the rail car?
I really hope I was able to give enough information if not please let me know. I have been goolging for the better part of the afternoon trying to figure this out with no luck. I'm hoping once i figure out the equation I can put it as part of my spread sheet to be sent in with the paperwork,
thank you very much
Michael
From the ideal gas law, the density of propane vapor at 53 F and 45 psi (I assume absolute pressure) is 0.36 lb/ft^3. 34000 gallons is 4545 ft^3. So the remaining mass is about 1600 lb. If converted to liquid, that would be about 350 gallons.
Likes berkeman
I had always figured it to be around 400 gallons or so but had not scientific proof to back it up! I have been trying to google a chart to give me the the density of propane vapor at a specific temp but can't come up with anything or... or..more likely I probably don't understand what I'm looking at
Is there a simple formula or chart that shows how to get to the 0.36 lb/ft^3.
thanks again sorry to be a bother.
Michael
Michael
Well, the ideal gas law is useful. From the ideal gas law, the density of the gas is given by:
$$\rho=\frac{pM}{RT}$$
where p is the absolute pressure (psi), M is the molecular weight (44), T is the absolute Rankine temperature (460 + F), F is the Fahrenheit temperature, and R is the universal gas constant 10.7 in corresponding units. ρ is the density in lb/ft^3.
Chet
thanks you very much for taking the time to help me out with this!
I know it has been more than a year since the conversation started so I am jumping in a little late. I too work for a propane company and have a similar issue. The question I have is how could we ensure that all of the propane on the car is offloaded.
It doesn't seem practical to try to offload all the vapors.
Related to Question about converting propane vapor volume to liquid gallons
1. How do you convert propane vapor volume to liquid gallons?
To convert propane vapor volume to liquid gallons, you will need to know the density of propane at the current temperature and pressure. Then, use the following formula: liquid gallons = vapor volume x density.
2. What is the density of propane at different temperatures and pressures?
The density of propane varies depending on the temperature and pressure. At standard temperature and pressure (STP), the density of propane is 2.0098 kg/m3. However, at lower temperatures and higher pressures, the density can increase significantly.
3. Is there a specific formula for converting propane vapor volume to liquid gallons?
Yes, there is a specific formula for converting propane vapor volume to liquid gallons. The formula is: liquid gallons = vapor volume x density. This formula takes into account the density of propane at the given temperature and pressure.
4. Can I use the same formula to convert any gas vapor volume to liquid gallons?
No, the formula for converting propane vapor volume to liquid gallons is specific to propane. Each gas has its own unique density and therefore requires a different formula for conversion.
5. How accurate is the conversion of propane vapor volume to liquid gallons?
The accuracy of the conversion depends on the accuracy of the given density value. If the density is measured accurately, the conversion should be fairly accurate. However, there may be other factors that can affect the accuracy, such as changes in temperature and pressure.
  • Other Physics Topics
14K
  • Mechanical Engineering
17K
10K
