Question about converting x = pi/6 to polar form
In summary, converting t = pi/6 into polar form involves using the equations x = r*cos(t) and y = r*sin(t). The correct answer is obtained by using tangent instead of cosine, as shown in the conversation. Squaring both sides can introduce incorrect solutions, making the tangent approach the best option.
ishanz
Convert t = pi/6 into polar form.
x = r*cos(t)
y = r*sin(t)
t = pi/6
cos(t) = cos(pi/6)
cos(t) = sqrt(3)/2
x/r = sqrt(3)/2
sqrt(3)r = 2x
sqrt(3)sqrt(x^2 + y^2) = 2x
sqrt(3x^2 + 3y^2) = 2x
3x^2 + 3y^2 = 4x^2
0 = x^2 - 3y^2
However, the book says to use tangent instead, as shown below:
t = pi/6
tan t = sqrt(3)/3
y/x = sqrt(3)/3
sqrt(3)x - 3y = 0
This is the correct answer. However, I do not understand why the answer I obtained is incorrect. Is it legal to cosine both sides as I did?
Actually the answer you got and the correct answer are nearly the same.
[tex]\sqrt{3}x-3y=0[/tex]
[tex]x-\sqrt{3}y=0[/tex]
[tex]x=\sqrt{3}y[/tex]
[tex]x^2=3y^2[/tex]
[tex]x^2-3y^2=0[/tex]
which is what you had. The only problem is that when you squared both sides you have introduced more solutions which are not correct. If we go backwards such as taking the square root of both sides we get:
[tex]x^2=3y^2[/tex]
[tex]x=\pm \sqrt{3} y[/tex]
and the solutions [itex]x=-\sqrt{3}y[/itex] are not correct.
It is difficult to avoid squaring in this line you had: [tex]\sqrt{3(x^2 + y^2)} = 2x[/tex] which is why using the tangent is the best approach.
Ahh, that makes a lot of sense. Thanks a lot!
You're welcome :smile:
FAQ: Question about converting x = pi/6 to polar form
How do you convert x = pi/6 to polar form?
To convert x = pi/6 to polar form, we first need to understand that pi/6 is a reference angle in the first quadrant. In polar form, we represent angles in terms of degrees or radians and distance from the origin. Since pi/6 is in the first quadrant, the angle in polar form would be 30 degrees or pi/6 radians. The distance from the origin would depend on the specific conversion task.
What is the formula for converting x = pi/6 to polar form?
The formula for converting x = pi/6 to polar form is r = x/cos(theta), where r represents the distance from the origin and theta represents the angle in radians. In this case, r would be the distance from the origin to the point (1, pi/6) and theta would be pi/6 radians or 30 degrees.
Why do we use polar form in mathematics?
Polar form is used in mathematics to represent complex numbers, vectors, and equations in a more convenient and efficient manner. It allows us to easily visualize and understand the magnitude and direction of a quantity, which may be difficult to do in Cartesian coordinates. Additionally, polar form has many applications in areas such as physics, engineering, and geometry.
Can you convert any angle to polar form?
Yes, any angle can be converted to polar form. The angle should be measured in radians and the distance from the origin can be calculated using the formula r = x/cos(theta), where x is the given angle and theta is the angle in radians.
Is there a difference between Cartesian and polar coordinates?
Yes, there are several differences between Cartesian and polar coordinates. In Cartesian coordinates, we represent points on a plane using x and y coordinates, while in polar coordinates, we represent points using an angle and distance from the origin. Additionally, in Cartesian coordinates, we measure angles using degrees, while in polar coordinates, we measure angles using radians.
