Question about copenhagen interpretation
In summary: position probability density is, might be localized within an uncertainty that is small compared to macroscopic scales or the accuracy of a position measurement, but it is not localized within a precisely determined location.
Nick V
58
Does the Copenhagen interpretation allow for particles(electrons) to be in more than once place at the same time. I am not talking about quantum superposition here. I'm asking if it allows for electrons to be in many places at once like the many worlds interpretation does.
And if it doesn't allow for electrons to be in many places at once, please explain why. Can one believe in the copenhagen interpretation while believing that electrons can be in many places at once?
Your question doesn't seem right to me. If we exclude superposition, even MWI doesn't admit that, because in MWI, different branches of wavefunction occur at different worlds and so in no single world you have two branches happening together. So not only Copenhagen interpretation doesn't allow that, but also MWI doesn't allow it too. In fact no theory should allow it because it causes inconsistency and is not physical.
That particles (quanta) are "located in several places at once" is a somewhat distorted view of modern quantum theory. Also there is no "Copenhagen interpretation" but several flavors of it. Even Heisenberg's and Bohr's version, who can be considered as the main "inventors" of the class of interpretations subsumed under "Copenhagen interpretation", differ. I'm myself a follower of the "minimal statistical interpretation", which is in my opinion also a kind within the Copenhagen family and the only one of all interpretations of the QT formalism I know so far which is strictly following the "no-nonsense approach" to physics, which means particularly not to make "esoteric" claims about the "meaning of the theory" but seeing it as a description of objectively observable facts about nature.
In this "minimal interpretation" the wave function (which makes sense only in the nonrelativistic limit; so I'll restrict myself to this limit, which however is already sufficient to understand an astoningishly wide range of phenomena in atomic and condensed-matter physics) describes the state of a single particle as a complex valued function ##\psi(t,\vec{x})##. This function must be square integrable, i.e., the integral
$$N=\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} |\psi(t,\vec{x})|^2$$
should be finite. Then one can multiply the wave function by a factor (which is determined only up to a phase factor, which is however irrelevant for the physical meaning of the wave function) such that
$$N=1.$$
Then, according to Born (1926) the modulus squared of the wave function is the position probability density,
$$P_{\psi}(t,\vec{x})=|\psi(t,\vec{x})|^2.$$
I.e., the probability to find the particle in a small volume element ##\mathrm{d}^3 \vec{x}## around the location defined by ##\vec{x}## is ##P_{\psi}(t,\vec{x}) \mathrm{d}^3 \vec{x}##.
Now the wave function can be narrowly peaked around one position. One can prove that there exist such functions with a "width" as small as you want, but there is no state where the width vanishes. This would be a Dirac ##\delta## distribution, but that's not a state because it's not a square-integrable function (even the square itself doesn't make mathematical sense!).
This implies that a quantum particle can never have a precisely determined location. You can give the probability to find the particle in a certain region in space, but never a certain position! This doesn't mean that the particle is at many positions at the same time. Strictly speaking it's even weirder! The particle has no clear position at all although its position can be arbitrarily well determined, i.e., the probability to find it can be very large at some volume small on everyday scales and practically 0 everywhere else; then we say the particle is localized within an uncertainty that is small compared to macroscopic scales or the accuracy of a position measurement.
Further, the quantum mechanical formalism teaches us that not all observables can have sharply determined values. The most famous example, which lead to the Copenhagen interpretation and the idea of complementarity by Bohr are position and momentum. According to quantum theory, a quantum particle cannot have both a quite sharply defined value of the the ##x## component of the position vector and the ##x## component of the momentum vector, but the standard deviations of these quantities, defined with the probability distributions given by any "allowed", i.e., square integrable wave function must obey the famous Heisenberg-Robertson uncertainty relation,
$$\Delta x \Delta p_x \geq \hbar/2.$$
That means: If we have a well-localized particle its momentum distribution is pretty broad and vice versa.
Likes bhobba
Most definitely not.
A quantum object is only ever observed to be in one place at a time.
What its doing when not observed is anyone's guess because the theory is silent about that.
Thanks
Bill
And is untestable, so is not scientific.
This is not agreed on in general. In Newtonian Mechanics, we can say where an object is when it is not observed. Yet Newtonian Mechanics is generally considered a scientific theory.
Yes, but you cannot distinguish between Newtonian Mechanics and the theory that everything goes to the Land of Oz when it is not observed, but follows the predictions of Newtonian Mechanics when it is observed.
I suspect you are right, and the alternative hypothesis is very beautiful. But I don't know that the alternative is without difficulties. Let's consider an EPR experiment in classical relativistic theory so that spacelike separated measurements are perfectly correlated due to classical correlations prepared at the source (no Bell inequality violation). If Bob assumes that Alice went to Oz when Bob was not observing her, then although he receives Alice's report of her measurement at spacelike separation when they meet up, that report is misleading, since she was in Oz until Bob observed her, and not at the distant spacetime location written in the report.
I expect that these difficulties are the reason why V50 limited his delightful alternative hypothesis to Newtonian mechanics... I wonder what experiment could test that hypothesis against my similar one involving Middle Earth? Now, let's try getting back to OP's question...
As the other comments in this thread and V50's somewhat tongue-in-cheek suggestion make clear, the Copenhagen interpretation does not say that the electron is in two places at once. It says that when we observe it we get one position and that's where the electron is. Obviously that does not preclude the possibility that the electron does all sorts of strange and wonderful things (visiting Oz or Middle Earth, being in two or two thousand places at once, growing legs and dancing, ...) when we aren't watching. But it also gives us no reason to think that any of things are in fact happening.
Likes bhobba and vanhees71
To be fair I also have to point out I also fell into similar woolly thinking when I first started posting on this forum and I had read quite extensively on QM from many sources such as Ballentine. Its a very easy trap to fall into thinking because of the principle of superposition it is in two places at once when not observed - but its still wrong.
Thanks
Bill
Related to Question about copenhagen interpretation
1. What is the Copenhagen Interpretation?
The Copenhagen Interpretation is a theoretical framework in quantum mechanics proposed by Niels Bohr and Werner Heisenberg in the 1920s. It states that a system cannot be fully described with classical mechanics and that the act of measurement or observation affects the behavior of particles.
2. What are the main principles of the Copenhagen Interpretation?
The main principles of the Copenhagen Interpretation include the wave-particle duality, uncertainty principle, and superposition. These principles suggest that particles can behave as both waves and particles, that there are inherent limitations in measuring certain properties of particles, and that particles can exist in multiple states at the same time.
3. How does the Copenhagen Interpretation differ from other interpretations of quantum mechanics?
The Copenhagen Interpretation differs from other interpretations, such as the Many-Worlds Interpretation and the Pilot-Wave Theory, in its emphasis on the role of the observer in determining the behavior of particles. It also does not attempt to provide a complete explanation for the underlying mechanisms behind quantum phenomena.
4. What are some criticisms of the Copenhagen Interpretation?
One criticism of the Copenhagen Interpretation is that it relies on the idea of wavefunction collapse, which has not been fully understood or explained. It also does not offer a clear explanation for the apparent randomness in measurement outcomes. Additionally, some scientists argue that it is incomplete and does not fully capture the complexity of quantum mechanics.
5. How has the Copenhagen Interpretation influenced scientific thinking?
The Copenhagen Interpretation has had a significant impact on the development of quantum mechanics and has shaped our understanding of the behavior of particles at the subatomic level. It has also sparked debates and further research into the nature of reality and the role of observation in scientific experiments.
