Question about copper(II) phthalocyanine structure
  • Thread starter jorgeluisg
  • Tags
    Structure
In summary, the dashed lines in the image represent a bond between the nitrogen atoms in the phthalocyanine and copper. This bond might help to coordinate the metal to the phthalocyanine, and might be important for the complex to function.
jorgeluisg
I am hoping someone might be able to explain the significance of the arrows in the following structural diagram of copper(II) phthalocyanine (CuPc).
http://upload.wikimedia.org/wikipedia/commons/e/ec/Copper_phthalocyanine.svg
Which I have also seen represented as dashed lines such as on http://www.chem.ox.ac.uk/course/ityeartwo/html/colgate2.htm page (near the bottom).
My background is in physics so my understanding of chemistry is very rudimentary. From what I can recall, copper(II) should take 2 electrons in order to become neutrally charged, while nitrogen should have 3 extra electrons. The two N-Cu bonds without arrows should then make everything charge neutral since these two nitrogens only bond to two carbons, leaving a spare electron on each to bond to Cu with.
What do the arrows (or dashed lines) then indicate? They appear to indicate a bond of some form, but why should copper want to bond, or the nitrogens for that matter, if they are charge neutral? My research seems to indicate that the arrow might represent a co-ordinate bond but, once again, I don't see why the nitrogens should want to give up or even share their electrons if they are already stable, nor why the copper should accept them for the same reasons.
There is either something I'm missing, or I've misunderstood the significance of the arrows. In either case, I hope someone will be able to explain their significance to me.
Thanks in advance
Chemistry news on Phys.org
It is commonly described as a coordination complex in the literature, and if you look it up at Sigma-Aldrich they draw it with four equal bonds:
http://www.sigmaaldrich.com/large/structureimages/19/mfcd00010719.png
Once the metal-free phthalocyanine complexes a metal such as copper, all four of the inner nitrogen atoms are included in the coordination sphere. Formally speaking, one convention (in my experience) is to draw the bonds from the nitrogen atoms which lose the protons in the metal-free form and indicate that the other two nitrogen coordinate to the metal either through arrows or a dashed-line.
One of my favorite websites ChemSpider actually has an ionic form of this compound (a +2 charge on the copper, and a -2 charge on the phthalocyanine).
FAQ: Question about copper(II) phthalocyanine structure
1. What is the chemical formula of copper(II) phthalocyanine?
The chemical formula of copper(II) phthalocyanine is C32H16CuN8.
2. What is the molecular structure of copper(II) phthalocyanine?
The molecular structure of copper(II) phthalocyanine is a large, flat aromatic molecule with four isoindole units connected to a central copper atom.
3. What is the color of copper(II) phthalocyanine?
Copper(II) phthalocyanine is a blue-green color in its solid form, but can appear as a dark blue or greenish-blue powder or crystals.
4. How is copper(II) phthalocyanine used in industry?
Copper(II) phthalocyanine is used as a pigment in various industrial applications, such as inks, paints, and plastics. It is also used in the production of electronic devices, such as solar cells and batteries.
5. What are the properties of copper(II) phthalocyanine?
Copper(II) phthalocyanine has a high melting point, good thermal stability, and is insoluble in most solvents. It also exhibits good electrical conductivity and is resistant to oxidation and corrosion.
