Question about covariant derivatives
In summary: T^\lambda_{\ \ \lambda \rho}##Then we can take the covariant derivative to get a tensor of rank ##(1,3)##.This is a tensor of rank ##(1,3)## with one free index, ##\mu## and two contracted indices. To see this, we can write it as:##\sum_\lambda \nabla_\mu T^\lambda_{\ \ \lambda \rho}##So we went from rank ##(0,2)## to rank ##(1,3)##, just like in step 1.In this case, (3) is the statement that these two ways
George Keeling
41
I am reading I am reading Spacetime and Geometry : An Introduction to General Relativity -- by Sean M Carroll and have arrived at chapter 3 where he introduces the covariant derivative ##{\mathrm{\nabla }}_{\mu }##. He makes demands on this which are \begin{align}
\mathrm{1.\ Linearity:}\mathrm{\ }\mathrm{\nabla }\left(T+S\right)=\mathrm{\nabla }T+\mathrm{\nabla }S & \phantom {10000}(1) \nonumber \\
\mathrm{2.\ Leibniz\ rule:}\mathrm{\nabla }\left(T\ \otimes \ \ S\right)=\left(\mathrm{\nabla }T\right)\ \ \otimes \ \ S+T\ \otimes \ \ \left(\mathrm{\nabla }S\right) & \phantom {10000}(2) \nonumber \\
{\mathrm{3.\ Commutes\ with\ contractions:}\mathrm{\nabla }}_{\mu }\left(T^{\lambda }_{\ \ \ \lambda \rho }\right)={\left(\mathrm{\nabla }T\right)}^{\mathrm{\ \ \ }\lambda}_{\mu \ \ \lambda \rho } & \phantom {10000}(3) \nonumber\\
{\mathrm{4.\ Reduces\ to\ partial\ derivative\ on\ scalars:}\mathrm{\nabla }}_{\mu }\phi ={\partial }_{\mu }\phi & \phantom {10000}(4) \nonumber \\
\end{align}1,2 and 4 seem reasonable but I cannot understand 3 and he does not seem to use it, even though he implies that he does.
The LHS of (3) seems straight forward\begin{align}
{\mathrm{\nabla }}_{\mu }\left(T^{\lambda }_{\ \ \ \lambda \rho }\right) & ={\partial }_{\mu }T^{\lambda }_{\ \ \ \lambda \rho }+{\mathrm{\Gamma }}^{\lambda }_{\mu \kappa }T^{\kappa }_{\ \ \ \lambda \rho }-{\mathrm{\Gamma }}^{\kappa }_{\mu \lambda }T^{\lambda }_{\ \ \ \kappa \rho }-{\mathrm{\Gamma }}^{\kappa }_{\mu \rho }T^{\lambda }_{\ \ \ \lambda k} & \phantom {10000}(5) \nonumber \\
& ={\partial }_{\mu }T^{\lambda }_{\ \ \ \lambda \rho }-{\mathrm{\Gamma }}^{\kappa }_{\mu \rho }T^{\lambda }_{\ \ \ \lambda k} & \phantom {10000}(6) \nonumber \\
\end{align}Which is very like the rule for the covariant derivative of a (0,1) tensor.
I understand that the ##\mathrm{\nabla }T## in (1) and (2) means ##{\mathrm{\nabla }}_{\sigma}T## where ##T## is some tensor. So the RHS of (3) appears to be ##{\left({\mathrm{\nabla }}_{\sigma}T\right)}^{\mathrm{\ \ \ }\lambda}_{\mu \ \ \lambda \rho }## which leaves too many indices on the RHS. Otherwise the RHS is some kind of derivative with one contra- and three co-variant indices. What is that?
Help!
(3) is essentially what gives you the action on covariant indices (i.e., the negative sign that appears), which you have used when you say that it is straight-forward.
##\nabla## in ##\nabla T## generally does not need an index. If ##T## is a ##(n,m)## tensor, then ##\nabla T## is a ##(n,m+1)## tensor. Both (1) and (2) are written in non-index form. In general, ##\nabla T## is defined according to
(\nabla T)(V, \ldots) = (\nabla_V T)(\ldots),
where ##\ldots## are the arguments of ##T##. (Note that ##\nabla_V T## is an ##(n,m)## tensor if ##T## is.)
Here's the way I understand #3.
##g^{\lambda \nu} (\nabla_\mu T_{\nu \lambda \rho}) = \nabla_\mu (g^{\lambda \nu} T_{\nu \lambda \rho})##
Likes George Keeling
There is nothing generally stating that there needs to exist a metric. Instead, (3) essentially gives the relation between the actions of the covariant derivative on upper/lower indices. More specifically, if you define ##\nabla_\mu v^\nu = \partial_\mu v^\nu + \Gamma^\nu_{\mu \lambda} v^\lambda##, then you must have (from (2), (3), and (4))
\nabla_\mu(v^\nu\omega_\nu) = v^\nu \partial_\mu \omega_\nu + \omega_\nu \partial_\mu v^\nu = \omega_\nu \nabla_\mu v^\nu + v^\nu \nabla_\mu \omega_\nu
= v^\nu \nabla_\mu \omega_\nu + \omega_\nu \partial_\mu v^\nu + \Gamma^\lambda_{\mu\nu} v^\nu \omega_\lambda.
Solving for ##\nabla_\mu \omega_\nu## then leads to (also using the quotient rule)
\nabla_\mu \omega_\nu = \partial_\mu \omega_\nu - \Gamma^\lambda_{\mu\nu} \omega_\lambda.
Amazingly I had just read $$g_{\mu \lambda} \nabla_\mu V^\lambda = \nabla_\rho (g_{\lambda \mu} V^\lambda)$$in the book and I was trying to work out how it came from (3). stevendaryl has delivered me. It's very like
stevendaryl said:
Here's the way I understand #3. $$
So I'll take that (slightly generalised) as the answer! Thanks stevendaryl.
It does not come from (3), it comes from requiring that the connection is metric compatible, i.e., that ##\nabla g = 0##, which is a completely separate condition (and after that it follows from (2) and (3)). (3) is a requirement for any connection.
But as Orudruin points out, what I said is not exactly correct. In the case (which is true in General Relativity) where there is a metric and the connection is compatible with the metric, then it's basically close.
The issue of "commuting with contractions" is more general than manifolds with a metric.
1. Take covariant derivative, then contract:
If ##T^\nu_{\ \ \lambda \rho}## is a tensor of rank ##(1,2)## (1 upper index, 2 lower indices), then we can get another tensor by taking the covariant derivative:
##\nabla_\mu T^\nu_{\ \ \lambda \rho}##, which is of rank ##(1,3)##.
You can then contract ##\lambda## and ##\nu## to get a tensor of rank ##(0,2)##:
That has two free indices, ##\mu, \rho##
So we went from rank ##(1,2)## to rank ##(1,3)## to rank ##(0,2)##
2. Contract, then take covariant derivative:
Alternatively, we can first contract to get ##\sum_\lambda T^\lambda_{\ \ \lambda \rho}##, which is of rank ##(0,1)##. Then we can take a covariant derivative to get:
##\nabla_\mu \sum_\lambda T^\lambda_{\ \ \lambda \rho}##, which again has two free indices, ##\mu, \rho##.
This time, we went from rank ##(1,2)## to ##(0,1)## to ##(0,2)##
Saying that contraction commutes with covariant derivatives says that the resulting ##(0,2)## tensors are the same.
I have trouble writing all the indices correctly, but I think this is the identity:
##(\nabla_\mu T)^\lambda_{\ \ \lambda \rho} = \nabla_\mu (T^\lambda_{\ \ \lambda \rho})##
I love the idea that we can 1. Take covariant derivative, then contract or 2. Contract, then take covariant derivative and get the same answer. It sounds like commuting over contraction. But unfortunately I get 1. $$
\sum_\lambda \nabla_\mu T^\lambda_{\ \ \lambda \rho}=\nabla_\mu (T^\lambda_{\ \ \lambda \rho})
$$ and 2. $$
\nabla_\mu \sum_\lambda T^\lambda_{\ \ \lambda \rho}=\nabla_\mu T^\lambda_{\ \ \lambda \rho}=\nabla_\mu ( T^\lambda_{\ \ \lambda \rho})
$$So, sadly, this appears to be a statement of the obvious. I also wrote the summations out explicitly and 1 and 2 are the same by the linearity rule (1).
Going back to
A thousand apologies: I made a mistake in the equation I found and omitted the last part. It is (3.24) in the book and should have been: $$
g_{\mu \lambda} \nabla_\rho V^\lambda = \nabla_\rho (g_{\lambda \mu} V^\lambda) = \nabla_\rho V_\mu
$$ Leibniz (2) gives $$
\nabla_\rho (g_{\lambda \mu} V^\lambda) = V^\lambda \nabla_\rho g_{\lambda \mu} + g_{\lambda \mu} \nabla_\rho V^\lambda
$$ and metric compatibility (which Orodruin cleverly detected) makes ##\nabla_\rho g## vanish. The next step is $$
g_{\lambda \mu} \nabla_\rho V^\lambda = \nabla_\rho V_\mu
$$which is using (3)??
So the use of rules is in a slightly different order to what Orodruin suggested. But it's a miracle to get so far with a wrong and incomplete equation. That usage of (3) (which does not depend on the fact that the metric was the tensor involved) makes me want to rewrite it as:$$
T \nabla_\rho S = \nabla_\rho TS
$$ if an index in ##T## and ##S## is contracted. Indices have been omitted in the above expression, but I don't know how to put them in in a general enough way. (They could be many up or down indices.) This is a generalisation of what StevenDaryl wrote yesterday: ##
Related to Question about covariant derivatives
1. What is a covariant derivative?
A covariant derivative is a mathematical operation that extends the concept of a derivative to curved spaces. It takes into account the curvature of the space and allows for the differentiation of vector fields and tensors.
2. How is a covariant derivative different from an ordinary derivative?
Unlike an ordinary derivative, which only considers changes in a single direction, a covariant derivative takes into account changes in all directions in a curved space. It also takes into account the connection between different points in the space.
3. What is the importance of covariant derivatives in physics?
Covariant derivatives are essential in the study of general relativity and other branches of physics that deal with curved spaces. They allow for the formulation of equations that accurately describe the behavior of physical quantities in curved spaces.
4. How is a covariant derivative calculated?
The calculation of a covariant derivative involves taking the ordinary derivative of a vector or tensor field and adding correction terms that account for the curvature of the space. These correction terms are determined by the connection coefficients of the space.
5. Can you give an example of a physical phenomenon that can be described using covariant derivatives?
One example is the motion of objects in a gravitational field. The acceleration of an object in a gravitational field can be described using a covariant derivative, taking into account the curvature of space caused by the presence of massive objects.
