Question about derivative of an integral
In summary: The First Fundamental Theorem of Calculus is more often expressed as:\int_a^b f(x)dx = F(b) - F(a), where F(x) is the antiderivative of f(x), as defined in part 2) above.Actually, the FTC says that ## \frac {d}{dx} \int_0^x f(t)dt =f(x) ## for any function f(x) and any real number x.
Mr Davis 97
1,462
44
What does it mean to say that ##\displaystyle\frac{d }{d x}\int f(x)dx = f(x)##? Does this somehow relate to the fundamental theorem of calculus? If so, how?
What is the fundamental theorem according to you?
It means that if you find $$F(x) = \int {f(x)dx}$$ (i.e. the antiderivative, a.k.a. indefinite integral) and then you find $$\frac{d}{dx}F(x)$$ you get ##f(x)## back again.
Another way to look at it is that differentiation and antidifferentiation are inverse operations.
The "Fundamental Theorem of Calculus" has two parts:
1) If we define [itex]F(x)= \int_a^x f(x)dx[/itex] then [itex]dF/dx= f(x)[/itex].
2) If f(x)= dF/dx then [itex]F(x)= \int f(x) dx+ [/itex] some constant.
How are those two parts different? Also, isn't there a part that relates the definite integral to the antiderivative?
In 1) above, F(x) is the antiderivative of f(x).
[itex]\int_a^b f(x)dx = F(b) - F(a)[/itex], where F(x) is the antiderivative of f(x), as defined in part 2) above.
FAQ: Question about derivative of an integral
What is the derivative of an integral?
The derivative of an integral is the function that represents the rate of change of the integral with respect to its variable. It can also be thought of as the slope of the tangent line to the curve of the integral.
How do you find the derivative of an integral?
The derivative of an integral can be found by using the Fundamental Theorem of Calculus, which states that the derivative of an integral is equal to the integrand evaluated at the upper limit of integration.
Why is the derivative of an integral important?
The derivative of an integral is important because it allows us to find the rate of change of a quantity that is changing continuously over a given interval. This is useful in many scientific and mathematical applications, such as calculating velocity, acceleration, and growth rates.
Can the derivative of an integral be negative?
Yes, the derivative of an integral can be negative. This indicates that the integral is decreasing over the given interval. In other words, the slope of the tangent line to the integral curve is negative.
Is there a difference between the derivative of an integral and the integral of a derivative?
Yes, there is a difference between the derivative of an integral and the integral of a derivative. The derivative of an integral represents the rate of change of the integral, while the integral of a derivative represents the accumulation of the derivative over a given interval.
