MHB Question about errors in Numerical Analysis
In Numerical Analysis, subtracting two nearly equal numbers can lead to significant errors due to limitations in floating-point representation. For example, calculating 1.000001 - 1 results in a small value of 0.000001, but the accuracy of this result is affected by the precision of the original numbers. The inherent accuracy of each number is approximately ±0.0000005, which translates to a relative error of 50% for the result. This illustrates how small differences can lead to disproportionately large errors in numerical computations. Understanding these concepts is crucial for effective numerical analysis.
evinda
MHB
Hey! I am looking at an exercise in Numerical Analysis and I got stuck.
Why do we have a huge error when we substact two almost equal numbers?
Mathematics news on Phys.org
Hey evinda!
Suppose we calculate $1.000001 - 1$.
In a "float" you can only keep 7 significant digits, so the first number cannot have more reliable digits than it already has.
The accuracy of both numbers is $\pm 0.0000005$.
Or as a percentage: $$\frac{0.0000005}{1} \times 100\% = 0.00005 \%$$, which is a pretty small error.The result of the subtraction is $0.000001$, but its accuracy is still about $0.0000005$.
Or as a percentage $$\frac{0.0000005}{0.000001} \times 100\% = 50 \%$$I'd say that is quite a large error relatively speaking. Don't you?
Great...I got it...Thank you very much! :o
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
