Question about finding the amplitude of this circular wavefront
In summary: I'm not sure what you're asking. You might be looking for an equation that relates power to amplitude, speed to frequency, or Euler's equation. I'm not sure what you're asking. You might be looking for an equation that relates power to amplitude, speed to frequency, or Euler's equation.
randyrandy
A transverse circular wave propagates on a plane surface without energy dissipation. If the wave amplitude is 2 cm at a distance of 10 cm from its centre, what is the wave amplitude at a distance of 40 cm from its centre?
answer is 1cm.
speed = frequency*wavelength
I'm stumped. How do you get this without knowing the wavelength? Can someone explain how to get the answer?
randyrandy said:
Homework Statement:: A transverse circular wave propagates on a plane surface without energy dissipation. If the wave amplitude is 2 cm at a distance of 10 cm from its centre, what is the wave amplitude at a distance of 40 cm from its centre?
answer is 1cm.
Relevant Equations:: speed = frequency*wavelength
What expressions do you have for the relationship between amplitude and energy or power?
Part of what threw me off was I was uncertain whether the amplitude of 2cm is the peak amplitude for the wave or some height between the maximum amplitude.
As to the power equation, I'm not sure. The problem didn't mention anything about power. Oh, wait, energy is conserved so this is really about energy distributed over a greater area which translates to amplitude? so at radius of 10 it's 2cm. so at radius of 40cm, there must be a ratio? something to do with pi*r^2? something drops off exponentially as you go further out from center. (sort of like sound or light that dims the further you are from the source like stars?) 100/1600 = x/2cm. but then the answer is 2/16 or 1/8th. not sure...
Likes Lnewqban
Think about a single circular wavefront. As it travels out it is distributed over a greater...?
The way amplitude relates to energy is crucial. What do you know about waves?
Not exponentially.
Likes Lnewqban and tech99
maybe circumference? rather than area, just the perimeter of the wave front? so it's pi*2*r? so linear? just intuitively, i know that a ripple will die down as the wave moves from the center...so the amplitude will be smaller...so it'll be inverse relationship to distance.
2*10cm = 1/2cm,
2*40cm = 1/xcm
10cm/40cm = x/2
x = .5cm
but that's not the answer...
Yes, the problem said this is a circular wave front in a plane surface. So the "wave front" is a circle and it length is proportional to the radius of the circle. 40 cm is 4 times as much as 10 cm so the wave front is 4 as long. Since the wave height is 2 cm at 10 cm radius, the energy will be spread over 4 times the length. The wave height at 40 cm will be 2/4= 1/2 cm.
  • Skeptical
Likes hutchphd
But the answer says it's 1cm not 0.5cm...
Then that answer is wrong!
How is energy related to amplitude?
Likes Merlin3189
You overlooked this part of my post:
Or think about SHM, which is essentially wave motion. How does energy in a spring relate to displacement?
Likes Merlin3189
No, I’m afraid it is right.
I'm confused more than ever...
Then I will ask you again
1/2kx^2? = energy. but that formula doesn't have radius as a variable.
Could you explain how to solve this problem?
If you recall, I was trying to get you to think about the relationship between energy and amplitude in waves. In waves and SHM, amplitude is max displacement from equilibrium.
I found this formula for a spring F=kx. Would that be applicable here?
No, you already have the relevant spring formula, E=½kx2. You just need to see what the max displacement of an oscillating spring corresponds to in wave motion.
Would the problem assume that 2cm is the max displacement at 10cm from center? This seemed ambiguous to me.
therefore... 1/2k4 = energy (energy would be proportional to circumference pi*2*10cm) at 10cm. at 40cm... 1/2kx^2. what would the energy side of the equation look like at 40cm? pi*2*40cm?4/x^2 = 40/10 , x = 1cm.
holy crap.
wow! that was totally not intuitive. what am i missing in terms of connecting that pivotal spring formula to wave propogation?
formally speaking, what energy equation would be used on the other side of 1/2kx^2 = ? that uses radius in it's equation?
Yes, that's what wave amplitude means. It is the max displacement from the mean position.
For a surface wave on water, the mean position is where the surface would be if not for the wave, so the amplitude is the height of a wave crest above that.
For a longitudinal wave, such as an air column in a pipe, each molecule is oscillating back and forth parallel to the axis of the pipe. For a given molecule, its amplitude is its maximum displacement from its mean position. The molecules with the greatest amplitude will be at the antinodes (unless I've confused nodes and antinodes again).
In general, we can write a traveling wave as y=A sin(kx-ωt), for suitable choices of x=0 and t=0. y here is the displacement of the particle at position x at time t. The velocity of that particle is therefore Aω cos(kx-ωt), and its peak speed is |Aω|. So its peak KE is as (Aω)2. For a given frequency, the energy content is proportional to the square of the amplitude.
It is also interesting to consider interference. Where waves cancel the amplitude is zero, and where they maximally reinforce the amplitudes add up. If the energy were only proportional to the amplitude we would find that the total energy over the area must be less than the sum of the energies of the individual waves. But because it is proportional to the square of the amplitude it turns out that the integral over the area gives the same energy as by adding the energies of the two waves.
Likes hutchphd and Lnewqban
Thank you for that explanation.
why are water waves considered harmonic motion? i thought harmonic meant things like springs and pendulums and stuff?
I think you have the ideas. You just haven’t put them together. You were thinking correctly when you decided the energy should remain constant and so the energy density had to drop with the circumference. That’s what relates to the radius. Energy conservation. Your only mistake in that reasoning was equating energy to amplitude.
I'm still uneasy because I still don't see a concrete formula(s) connecting energy and radius to amplitude... I'm curious to find out what the formal way of solving this would be using nice neat physics formula.
Related to Question about finding the amplitude of this circular wavefront
1. How do you define amplitude in a circular wavefront?
The amplitude of a circular wavefront is the maximum displacement of the wave from its equilibrium position. It represents the strength or intensity of the wave.
2. Can the amplitude of a circular wavefront change?
Yes, the amplitude of a circular wavefront can change depending on the source of the wave and the medium it travels through. It can also change due to factors such as interference and diffraction.
3. How is the amplitude of a circular wavefront measured?
The amplitude of a circular wavefront can be measured by finding the maximum displacement of the wave from its equilibrium position. This can be done using instruments such as an oscilloscope or by analyzing the wave equation.
4. What is the relationship between the amplitude and energy of a circular wavefront?
The amplitude and energy of a circular wavefront are directly proportional. This means that as the amplitude increases, so does the energy of the wave. This is because a larger amplitude represents a stronger wave with greater energy.
5. How does the amplitude of a circular wavefront affect its wavelength and frequency?
The amplitude of a circular wavefront does not directly affect its wavelength or frequency. However, it is indirectly related as a higher amplitude wave may have a shorter wavelength and higher frequency compared to a lower amplitude wave. This is because the energy of the wave is distributed over a smaller distance, resulting in a higher frequency.
  • Classical Physics
