Question about Gravity and ratio of attraction
In summary, Gerald stands 3.77x10^8 m from the center of the moon. If the mass of the Earth is 5.96x10^24 kg, and the radius of the Earth is 6.39 x 10^6 m, then the ratio of (Gerald's attraction to the moon) to (Gerald's attraction to the earth) is 3.71x10^{8}.
Freemark
Gerald stands on the roof looking up at the full moon, which has a mass of 7.39 x 10^22 kg. At this moment, Gerald is 3.77 x 10^8 m from the center of the moon. If the mass of the Earth is 5.96 x 10^24 kg, and the radius of the Earth is 6.39 x 10^6 m, what is the ratio of (Gerald's attraction to the moon) to (Gerald's attraction to the earth)?
F=G[itex]\frac{M1*M2}{r^2}[/itex]
So the first thing I know I need to solve for is the radius of the moon. I wasn't sure how to go about this so I decided that R[itex]_{Gerald from moon}[/itex] - R[itex]_{Earth}[/itex] = R[itex]_{Moon}[/itex] I feel like that's wrong, but I got an answer of 3.71x10[itex]^{8}[/itex].
Next I tried to use the gravity formula (posted above) to find the "F" values for the moon and the earth. I got:
F[itex]_{moon}[/itex] = 7.927x10[itex]^{28}[/itex] and
F[itex]_{earth}[/itex] = 4.597x10[itex]^{30}[/itex]
Then I just divided the moon value by the Earth value to get a ratio. The answer wasn't correct, and I feel like it has to do with the first part. Problem is, I have no idea where to go. Some help would be appreciated.
There is no reason to do this.
How far is Gerald from the center of the moon? How far is Gerald from the center of the Earth?
Well, now that you mention it, it seems like I was finding the ratio of attraction between the Earth and the moon...
Those values were given, so I'm assuming that's what I'm supposed to be using. Alright, I think I get this. I shouldn't need to worry about Gerald's mass right?
It would cancel, yes.
After taking another stab at the problem, I got another wrong answer. What I was trying to do was find Fm and Fe (through the formula posted). I used the distance that Gerald was from the moon (I used that as the radius value) to find Fm, then I found Fe and divided Fm/Fe. Could you explain to me what I'm doing wrong?
Would you mind posting the solution you have in terms of variables (i.e. no numbers)?
Sure. I have:
Ratio = Fm/Fe
Thus:
Ratio = G*M[itex]_{M}[/itex]*M[itex]_{E}[/itex]*[itex]\frac{1}{rm^2}[/itex]/G*M[itex]_{M}[/itex]*M[itex]_{E}[/itex]*[itex]\frac{1}{re^2}[/itex].
So the G and M's cancel out and I'm left with [itex]\frac{1}{rm^2}[/itex]/[itex]\frac{1}{re^2}[/itex]
That equals [itex]\frac{re^2}{rm^2}[/itex]
Where rm = Radius of Gerald from the moon
and re = Radius of the Earth given in the problem.
You are using the wrong values for the masses. Think about how you would set up the problem if the question simple asked what is Gerald's attraction to the Earth.
There's your problem. You have to recognize that you're finding two separate forces: one between Earth and Gerald, and one between the Moon and Gerald. Thus, the masses need to be Earth's and Gerald's, and the Moon's and Gerald's. The masses of the Earth and the Moon do not cancel out of the ratio; only Gerald's mass will cancel.
You should put Gerald's mass in and cancel it out yourself. I think that it will help you to work through the problem without making mistakes if you do it that way.
Oh ok! So I redid the problem and I'm left with M[itex]_{m}[/itex]*[itex]\frac{1}{rm^2}[/itex]/M[itex]_{e}[/itex]*[itex]\frac{1}{re^2}[/itex] (where rm is Gerald's distance from the moon). I'm assuming that's my real answer.
Looks kosher, yes.
yep, nice work
Alrighty then, thank you all!
Related to Question about Gravity and ratio of attraction
1. What is gravity?
Gravity is a force that exists between any two objects with mass. It is the force that pulls objects towards each other.
2. How does gravity work?
Gravity works by the principle of mass attraction. The more massive an object is, the more gravitational force it has. This force decreases as the distance between the objects increases.
3. What is the ratio of attraction in gravity?
The ratio of attraction in gravity is known as the gravitational constant, which is approximately equal to 6.674 x 10^-11 Nm^2/kg^2. This constant determines the strength of the gravitational force between two objects with a given mass and distance.
4. Does the ratio of attraction in gravity change?
No, the ratio of attraction in gravity remains constant, regardless of the mass and distance between the objects. This is known as the universal law of gravitation.
5. How does gravity affect the motion of objects?
Gravity affects the motion of objects by pulling them towards the center of the larger object. This causes objects to accelerate towards each other, resulting in orbital motion or falling towards the surface of the larger object.
