Question about gravity and the shell theorem
In summary, the conversation discusses the concept of gravitational acceleration of a test particle in a homogeneous and isotropic universe. The first paragraph suggests that the test particle should accelerate towards point X due to the gravity of all matter within a certain radius, while the shell theorem states that the gravity from all matter outside that radius should cancel out. However, the second paragraph raises questions about this reasoning, ultimately leading to the conclusion that the test particle's motion is affected by the expansion of the universe rather than the gravity of the point mass at X. Additionally, it is noted that the homogeneity and isotropy of the universe would not allow for the exclusion of the influence of the mass attracting the test particle.
mrspeedybob
869
65
Consider a point in the universe I'll call X and a test particle some distance R away. For the purposes of calculating the gravitational acceleration of the test particle I'll consider all the matter within radius R of point X to be a point mass attracting the particle to X. Furthermore, all the gravity from all the matter outside this sphere should cancel out per the shell theorem. So, I conclude that the test particle accelerates towards X.
But that can't be right. in a homogeneous and isotropic universe the test particle won't prefer to accelerate in any particular direction because they are all the same. What is wrong with the reasoning in my first paragraph?
Space news on Phys.org
The gravitational force from the matter outside R only cancels out if said matter is in uniform spherical distribution. Can you say that about matter distribution in a homogeneous and isotropic universe?
Shell theorem is a consequence of inverse square law of gravity which is true only in the weak field and low speed limit of General Relativity.
(I also give a vote for Bandersnatch's objection! In fact that's the main thing.)
The first obvious question to ask is, what if the radius R is zero? I.e., what if the test particle itself is at point X? In that case all the gravity from the matter everywhere else cancels out and the test particle remains at point X. (Yes, the shell theorem is valid in this case--see below.)
The second question is then: why should changing where we pick point X to be change the behavior of our test particle? Obviously it shouldn't. So we must be making some error in our analysis of the case where R is nonzero. It isn't the shell theorem (again, see below). So it must be the other part, where we calculate the motion of the test particle relative to point X when R is nonzero.
Try this way of looking at it: put a second test particle at point X, so we have two test particles a distance R apart, both in free fall. Are they at rest relative to each other? No; they are not. Both test particles are following "comoving" worldlines (by hypothesis), and comoving worldlines are moving apart, because the universe is expanding. But the claim that the gravity of the "point mass" at X would make the test particle at radius R from X fall towards it was, implicitly, based on an assumption that the test particle starts out at rest relative to point X. In fact, it isn't; it's moving outward. So the gravity of the "point mass" at X will not cause an acceleration of inward motion of the test particle; it will cause a deceleration of the outward motion of the test particle.
And, in fact, if we look at what happens in a matter-dominated universe (which we have also been implicitly assuming, based on how we expect the gravity of the point mass at X to act), this is exactly what happens! The matter in the universe causes the expansion of the universe to decelerate. And the scenario we've just described explains why, from a local viewpoint; in other words, it explains why an observer at X would compute that the test particle at R should decelerate its outward motion, relative to him.
Yes. A homogeneous and isotropic universe is spherically symmetric about any point. So this escape route won't work.
The Newtonian version of the shell theorem is a consequence of the inverse square law of gravity. The GR version of the shell theorem is true in any spherically symmetric spacetime. So this escape route won't work either. But fortunately you don't need an escape route; see above.
I was hoping to elicit this answer from the OP. Once this is realized, it's easy to exclude the influence of the mass that's supposed to be attracting the test particle simply by choosing a different mass for which the previous one constitutes the shell.
I'm not sure exactly what you mean by "choosing a different mass", unless it's just to make the first point I made, that if we put the test particle at point X all the mass in the universe is in the "shell".
But in any case, as the rest of my post shows, the intuition that, if we put the test particle somewhere other than point X, the mass closer to X can be treated as a point mass at X, is correct. That mass does attract the test particle. The incorrect implicit assumption in the OP's post was that the test particle starts at rest relative to X. In fact, it's moving outward, so the effect of the "point mass" at X is to decelerate it.
Yes. No disagreement with your posts, at least none intended. Although I'd rather let the OP get there himself.
I think Bandersnatch, Peter, and Shyan have addressed this and there probably isn't anything anyone needs to add. I just want to mention something related in an odd way, to your question about the shell theorem. This is about Newtonian gravity in ordinary Euclidean space. Something fun to consider.
Imagine a infinite block of material with uniform density (say Euclidean R3 filled with material the average density of the Earth.)
Imagine a spherical bubble the size of the Earth removed from it. You and your friends get to explore inside that hollow sphere. What is the gravity like?
It is the same as normal Earth gravity, only reversed, so it is outwards. You walk on the inside of the sphere and your weight feels the same.
(I am neglecting the fact that the Earth is not a perfect sphere and its sealevel gravity varies with latitude due to rotation etc etc. Let's idealize and speak approximately : ^)
At first this seems funny because wouldn't the complement of a round ball be LIKE a very thick shell? Why wouldn't there be zero gravity inside the bubble?
But it has to be that way because ball that we imagined being REMOVED was the size and density of the Earth. So its gravity would have to exactly cancel the gravity inside the hollow ball you are exploring. Gravity inside the hollow ball has to be equal and opposite to that on Earth.
Likes Jonathan Scott
Isn't this impossible in Newtonian gravity? The gravitational potential energy would be minus infinity at every point.
I see it as redefining vacuum and then that bubble becomes a spherical distribution of negative mass.
I think you can see how to make the example more like our actual universe :)
Use a different density, much lower than that of Earth. Closer to the actual average density of matter we measure. If you like, say it is Einstein gravity. If you want, adjust the cosmological constant the way Einstein originally wanted (it is an ideal example) so that space can be flat and doesn't have to be expanding. Or let it be very gradually expanding. It doesn't matter. The idealized example is of an infinite flat universe, filled with uniform density ("homogeneous and isotropic"), with a spherical bubble removed.
You can make it as close as you want to the familiar infinite LambdaCDM case, homogeneous and isotropic except for a bubble removed. The gravity outwards on the inside of the bubble must be equal and opposite to the gravity inwards on the surface of the ball that was removed.
That is the puzzle---I don't want to intrude to much in Speedybob's thread, but wanted him to have this puzzle which is related to the one he originally asked about.
If you intend this as an actual puzzle, I'll refrain from commenting to give the OP a chance to respond. But just for the record, I do not think the gravity on the inside of the "bubble", if the mass inside the bubble were removed, would be as you describe; I think it would be zero, just as the shell theorem says.
Excellent, Peter! I think it is a good idea to let Speedybob have time to think, let us know if he is still interested, if he has any questions? Sees a flaw in his original problem?
I hope he's still around, but if he's moved on that leaves the rest of us to hash it out.
Hi Mr. Speedybob,
I thought you asked an intriguing question. Hoping you'll come back to it, ask more questions, guess at an answer. We kind of paused to see if you would comment, or draw some conclusions. If not then maybe later today others will try various ways to resolve the puzzle. (Or do you think it has already been resolved? How?)
I think to make the simplest assumption about context we should think of the standard LCDM cosmic model which is spatially flat infinite universe. And homogenous isotropic of course. That's the model cosmologists most often use and having it infinite makes it simpler to think about shells.
I was curious about what I highlighted. Can you explain why "gravity from all the matter outside this sphere should cancel out per the shell theorem" ?
Why can you apply the shell theorem when the shell is, so to speak, infinitely thick? Was it proved for that case? Hoping you are still around and still wondering about this.
That is an intriguing question. Both your conclusion in post 8 and Shyan's thought in post 10 make sense, and I can't find fault with them. On the other hand gravity is zero inside a shell, so should be zero inside 2 concentric shells, or 3 or 4 or infinite.
I'm still pondering...
Could it be the "infinite" that causes trouble?
You know how infinite series can be summed in various ways to give various different answers?
Have you looked at how the shell theorem is proved? Maybe it is proved only for shells with a definite thickness? An infinite "shell" is hardly a real shell, isn't it? It has no definite thickness and without that something might go wrong in the proof. I guess that's probably just one way to look at it, and there must be more pictorial intuitive ways.
Here's a thought. You are imagining filling infinite space with concentric spheres, perfect spheres. Suppose instead you fill it with lopsided spheres all of whose walls have been thickened on the East side, but they fit together perfectly because each one is swollen similarly on that side. Then each misshapen shell exerts a slight net pull to the east. So when you add their effects up you get a (possibly infinite) pull to the east. the fact that space is infinite let's you divide it up different ways.
Here's a numerical analogy. -1,-1,-1,0,1,1,1 (each -1 is a pull to the west, each 1 is a pull to the east) they add up to zero
As long as the double sided sequence is finite and symmetrical it will add to zero. The opposite pulls cancel.
-1,-1,-1,-1,0,1,1,1,1 ? Yes. But what about the infinite double sided series that goes out to infinity in either direction?
...-1,-1,-1,-1,0,1,1,1,1...
Suppose I add it up this way
...-1,-1,(-1,(-1,0,1,1),1,1)...
Each "sphere" or "shell" is giving me a net +1 pull to the east. And I have infinite resources so I can use up faster on the right and never run out.
What I'm saying is the sum of the doubly infinite series is not defined
...(-1,(-1,(-1,(-1,0,1,1),1,1)1,1,)1,1,)... This already gives a +4 pull to the east.
But if I arbitrarily decided to add it up in some other way, I could get zero every time. The way we did when it was finite and symmetric.
the problem is with the infinity. The lack of a definite thickness of the shell. So the "shell theorem" does not apply.
But there are other ways to calculate the gravity inside the spherical void :w
This will work if we're considering how to answer the question in GR; but not if we're considering how to answer the question using Newtonian gravity.
(I should clarify that the answer I gave in an earlier post, that I think gravity inside the "bubble" will be zero, was a GR answer, not a Newtonian answer. I'm still not sure the infinite case can be consistently modeled using Newtonian gravity.)
(I should also clarify that my "GR answer" was assuming a matter-dominated universe with zero cosmological constant. So it wasn't quite the same model as the standard LCDM model.)
FAQ: Question about gravity and the shell theorem
What is gravity?
Gravity is a natural phenomenon by which all objects with mass are brought towards each other. It is a fundamental force of nature that governs the motion of celestial bodies and objects on Earth.
What is the shell theorem?
The shell theorem is a mathematical law that states that the gravitational force exerted by a spherically symmetric object on a body outside of it is the same as if all of the object's mass were concentrated at its center. This theorem is also known as the "Law of Spheres."
How does the shell theorem relate to gravity?
The shell theorem provides a simplified method for calculating the gravitational force between two objects when one of them is spherically symmetric. It allows us to treat the spherically symmetric object as a single point mass located at its center, making calculations of gravitational force much easier.
What are the implications of the shell theorem?
The shell theorem has important implications in astronomy and physics. It helps us understand the gravitational interactions between large celestial bodies, such as planets and stars. It also allows us to make predictions about the behavior of objects in our solar system and beyond, based on their spherically symmetric nature.
Are there any limitations to the shell theorem?
Yes, the shell theorem only applies to objects that are spherically symmetric and have a uniform density. In reality, most objects are not perfectly spherical and have varying densities, so the shell theorem is an idealized model that may not always accurately represent the true gravitational forces at work.
