Question about gravity on a moving object
  • Thread starter Low-Q
  • Tags
    Gravity
In summary, if a spheric heavy object with uniform mass is traveling at high velocity through space, the gravitational force does not change in any direction as it only depends on the mass of the object. However, there may be additional effects due to the object's motion, such as the gravitomagnetic field and frame-dragging, but these are frame-dependent and may interact with other moving objects in complex ways.
Low-Q
I have a question about gravity on a moving object.
If a spheric heavy object with uniform mass is traveling at high velocity through space, will that object increase its gravity in front of it and decrease its gravity behind it, while gravity on the sides remains the same?
Vidar
I'm not sure what you mean when you say high velocity like 90% of light speed?
It seems you're referring to the Alcubierre Warp Drive:
http://en.wikipedia.org/wiki/Alcubierre_drive
If so then this warping of space is due to exotic matter (which we've never seen and don't even know if it exists) and not simply by movement of an object through spacetime.
And lastly there's frame-dragging:
http://en.wikipedia.org/wiki/Frame_dragging
which may be what you're thinking.
I don't know if my question is related to the links you gave me. Say the Earth is traveling extremely fast in one direction. Will a scale show my mass as different depending on where I am located on the earth?
With respect to what?
You should see no difference in any experiment that studies objects on the Earth (and that are moving along with it), using equipment on the earth. You may see differences in the apparent behavior of non-Earthly objects: other planets, stars, etc.
Vidar
No, the force doesn't depend on the motion of a sphere. Its gravitational field only depends on its mass. The gravitational force will be same in all four directions you mentioned.
There are three ways to answer this question.
1) Classical Mechanics only. There is no change. Gravity depends on mass only and propagates instantly.
2) Linearized Gravity. It's going to behave similar to a moving charge. The gravitational field will remain the same, but the body will also generate gravitomagnetic field, which will interact with other moving objects. Obviously, this is frame-dependent as pointed out earlier.
3) General Relativity. The object's gravity changes, and it produces frame-dragging effect. In many ways, it is similar to the above, in that it is frame-dependent and that it will interact in interesting ways to other moving objects. For a general mass configuration, it's an extremely complicated problem, but for a spherically symmetric body, the result can be obtained by changing the frame of Schwarzschild metric to arrive at the exact effect of the moving body.
Note that all of the strange effects in cases 2 and 3 happen primarily because of the choice of reference frame. If you pick one in which the massive object in question is static and the observer is moving, you can describe all of it in much simpler ways.
FAQ: Question about gravity on a moving object
How does gravity affect a moving object?
Gravity affects a moving object by constantly pulling it towards the center of the Earth, causing it to accelerate in a downward direction.
2. Does gravity change on a moving object?
No, gravity does not change on a moving object. The force of gravity remains constant regardless of an object's motion.
3. Can an object overcome the force of gravity while in motion?
Yes, an object can overcome the force of gravity while in motion if it has enough speed and a force that counteracts the force of gravity, such as thrust from a rocket.
4. How does the mass of a moving object affect gravity?
The mass of a moving object does not directly affect gravity. However, objects with greater mass will experience a greater force of gravity due to the larger amount of matter attracting them towards the Earth.
5. Does the direction of an object's motion affect gravity?
No, the direction of an object's motion does not affect gravity. Gravity always pulls an object towards the center of the Earth, regardless of its direction of motion.
10K
