I Question about Grover's algorithm
  • I
  • Thread starter Thread starter Malamala
    Algorithm
Malamala
Hello! I am just getting started learning about quantum computing so I apologize if this questions is trivial, but I am a bit confused about the Grover's algorithm. As far as I understand (I read it from here), assuming there is just one solution, you start with N qubits, you put them in an equal superposition (using Hadamard gates), you pass them thorough an oracle that inverts the phase of the right solution, then you have a diffuser operator that reflects this new vector relative to the original one and doing this ##\sqrt{N}## times you get a high probability of measuring the right solution. I think I understand the math behind it and the geometrical interpretation, but I don't understand how it is used in practice. What is that oracle? In both examples given on that page, in order to build the oracle i.e. to make sure that the right solution gets a minus sign, you need to know the right solution beforehand. But if you know it, you don't need an algorithm to find it. Can someone help me understand this? What is the oracle in a real problem and how can I implement it in practice without knowing the answer to my question beforehand? Thank you!
First, I'm not sure that it is used in practice.
The "oracle" is part of the Quantum Circuitry that determines exactly what problem is to be solved.
So in order to use Grover's algorithm, you need to write another algorithm that is specific to the problem you are attacking.
For example, let's say that you are looking for a large prime number - say greater that 2^1024. So your oracle might take 1024 bits that represent the last 1024 position of a 1025-bit number - the first bit in that number being a "1".
The oracle will now flip all 1024-bit codes that when combined with that initial "1" code for a prime number.
The key here is that the oracle does not flip a bit, it flips the phase of a full code. So with 1024 bits, you may have many billions of correct answers - and about 2^1024 incorrect ones.
When you apply Grovers algorithm, there is a good chance that you will get one of those primes - but, of course, you would check the result.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
