Question about higher dimensions and what connects them
In summary, the conversation is discussing the concept of reaching higher dimensions through the addition of perpendicular lines. It is noted that these additional lines do not have to be perpendicular, but it is simpler and neater to think of them in this way. The conversation also touches on the limitation of human perception and how it affects our understanding of higher dimensions. The conversation concludes by stating that our limited perception may make it seem as though we can only point in three dimensions, but in reality, we are constantly embedded in however many dimensions there are.
Cody Richeson
60
It's my understanding that, if we ignore the temporal dimension and just focus on spatial ones, then you get to the third dimension by starting with a point and adding perpendicular lines to them. Once you've done this a couple of times, you get three dimensions. Obviously, to the layman, it appears that there are no more perpendicular lines to add in order to reach higher dimensions. There are, of course, and in crude visual analogies a simple 4-dimensional cube appears to have diagonal lines protruding from the 3D dimensional edges. This is not how it "really" would look, as it's a shadow of the 4D actuality, but can anyone explain what direction these additional perpendicular lines are going in, and why they appear diagonal when downgraded to a shadowed projection? Also, why do the lines have to be straight, and why do they have to be perpendicular?
The additional lines do not go in any direction in which one can point, or that one can draw, as we can only point in three dimensions and draw in two. Drawings that show additional dimensions by diagonal lines are intended only to create intuition and have no mathematical rigour. Personally I find such drawings less than helpful, but if they help others than that's good for them.
The extra lines don't have to be perpendicular. But the only component of the new lines that is of interest is that which is perpendicular to all lines that have already been drawn, because when you remove the perpendicular component the remainder can be decomposed into a set of lines each of which is parallel to a line that has already been drawn. So one generally talks about a new line being perpendicular to the ones already drawn because it is simpler and neater.
You say the additional lines "do not go in any direction in which one can point," but we are constantly embedded in however many dimensions there are. I know we only perceive three, but if the dimensions are all there, all the time, then how come we can't point in the direction of additional lines?
Because at every instant in time we are in a three-dimensional spatial submanifold, and we can only point within that submanifold. The fact that that submanifold is embedded within an n-dimensional manifold does not change our submanifold, or where we can point, no matter how big n is.
Likes bhobba
Is that true, or does the limited perception of humans make it seem as though that were true?
Related to Question about higher dimensions and what connects them
What are higher dimensions?
Higher dimensions refer to dimensions beyond the three dimensions of length, width, and height that we experience in our everyday lives. In mathematics and physics, higher dimensions are used to explain and understand complex systems and phenomena.
How many dimensions are there?
The exact number of dimensions is a topic of debate and ongoing research. In traditional mathematics, there are an infinite number of dimensions. In physics, some theories suggest the existence of up to 11 dimensions, while others propose even more.
What connects higher dimensions?
The concept of "connection" in higher dimensions can be interpreted in different ways. In mathematics, higher dimensions are connected through mathematical equations and theories. In physics, the concept of "connection" can refer to the way that higher dimensions interact with and influence our three-dimensional universe.
How can we visualize higher dimensions?
Visualizing higher dimensions can be challenging since we are limited to three-dimensional perception. However, mathematicians and scientists use various techniques, such as projections, virtual reality, and mathematical models, to represent and explore higher dimensions.
What are the applications of studying higher dimensions?
The study of higher dimensions has practical applications in fields such as physics, computer science, and engineering. It can help us understand complex systems, develop new technologies, and make predictions about the behavior of the universe.
  • Other Physics Topics
  • Beyond the Standard Models
  • Science Fiction and Fantasy Media
