Question about intensity of EM waves
In summary: They only require this for a plane wave in a medium (or in free space). In other cases, such as standing waves, the relationship between E and B can be different. This is not a contradiction, but rather a result of the specific conditions and setup of the standing wave.
kelvin490
For electromagnetic wave if it's reflected from a perfect conductor standing wave can be form. I wonder why Poynting vector can be used to describe the intensity of standing EM wave. (see p.19 of http://web.mit.edu/viz/EM/visualizations/coursenotes/modules/guide13.pdf ).
From some textbooks the Poynting vector is used to describe the intensity of traveling wave. It is derived from wave without reflection and since Maxwell's equations are obeyed and therefore cB=E. However in standing wave since E=2Eo cos(kx)cos(ωt) and B=2Bo sin(kx)sin(ωt), the E and B do not obey cB=E at every point and the overall wave is not traveling in any direction.
Another question is, the Poynting vector of standing wave is pointing perpendicular to the E and B field and sometime has positive and negative value. It means that energy is transmitting to either directions in different times. However for standing wave cB=E is not obeyed, does it contradict Maxwell's equation?
Likes Gruxg
Hello,
One thing to keep in mind is that Poynting's vector is, well, a vector: ##\mathbf{S}=\mathbf{E}\times\mathbf{H} ##. You really do want to keep the vectorial nature whenever dealing with it. Also, Poynting's vector comes out of Poynting's theorem:
https://en.wikipedia.org/wiki/Poynting's_theorem
This is derived for any electromagnetic field, not just waves. (It does not matter whether or not E=cB). In your case you have no Joule heating (no ##\mathbf{J \cdot E}## term). Consider the integral version in the link: it simply says that for a volume V that is enclosed in some surface S, the electromagnetic energy stored int he volume (volume integral of u) decreases when there is a net flux of power through the surface (integral of Poynting vector).
For your case it would be interesting to compute and plot the terms in the differential version. In your case, if the waves are propagating in the ##\pm \hat{\mathbf{z}} ##, ## \nabla \cdot \mathbf{S} = \frac{\partial}{\partial z} S_z ##, where ##S_z## is the z component of the POynting vector.
jason
EDIT: I found the notes you referenced a little hard to skim - but in case you are not familiar with D and H in the link I gave, in free space (like you have), ##\mathbf{D}=\epsilon_0 \mathbf{E}## and ##\mathbf{B}=\mu_0 \mathbf{H}##.
Likes kelvin490
No. Maxwells equations do not require cB=E in all cases.
Likes kelvin490 and jasonRF
Related to Question about intensity of EM waves
1. What is the definition of intensity in the context of electromagnetic waves?
The intensity of an electromagnetic wave is a measure of the amount of energy it carries per unit area per unit time. It is also referred to as irradiance and is measured in watts per square meter (W/m²).
2. How is the intensity of an EM wave related to its frequency and amplitude?
The intensity of an EM wave is directly proportional to its frequency and the square of its amplitude. This means that as the frequency or amplitude increases, the intensity also increases.
3. Is there a maximum intensity that an EM wave can have?
No, there is no maximum intensity for an EM wave. However, as the intensity increases, the wave may become unstable and break down into smaller waves. This is known as the critical intensity.
4. How does the intensity of an EM wave change with distance from its source?
The intensity of an EM wave decreases with distance from its source. This is because the energy is spread out over a larger area as it travels, resulting in a lower intensity at further distances.
5. Can the intensity of an EM wave be increased or decreased?
Yes, the intensity of an EM wave can be increased or decreased by adjusting the amplitude or frequency of the wave. It can also be affected by the medium it travels through, as some materials may absorb or reflect the wave, changing its intensity.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
