A Question about Kelvin’s circulation theorem
  • A
  • Thread starter Thread starter Seyn
    Fluid dynamic
Kelvin's circulation theorem states that in inviscid flow with constant density and conservative body forces, the circulation around a contour is conserved for fluid particles. This raises the question of whether vorticity is also preserved for each fluid particle under these conditions. Analyzing the vorticity equation, it can be shown that under the same assumptions as Kelvin's theorem, the equation reduces to \frac{D\omega}{Dt} = 0, indicating that vorticity is indeed conserved. Therefore, Kelvin's theorem not only preserves circulation but also ensures the preservation of vorticity for fluid particles. This relationship highlights the fundamental principles of fluid dynamics in inviscid flows.
Seyn
In Currie’s fluid mechanics textbook, there is a statement “the vorticity of each fluid particle will be preserved.” as the result of Kelvin’s circulation theorem.
Kelvin’s circulation theorem claims that
For inviscid flow, constant density or barotropic fluid, conservative body force,
the circulation around an arbitrary contour is conserved following same fluid particle.
Does Kelvin’s theorem also guarantee the vorticity on each fluid particles? Why?
Take a look at the vorticity equation under the same conditions as Kelvin's circulation theorem. Does it reduce to \frac{D\omega}{Dt} = 0?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
