A Question about lifting of a function
  • A
  • Thread starter Thread starter MathLearner123
    Algebraic topology
MathLearner123
Theorem 1
Suppose that ##p : X \to Y## is a covering map. Suppose ##\gamma_0, \gamma_1 : [0, 1] \to Y## are continuous, ##x_0 \in X## and ##p(x_0) = \gamma_0(0) = \gamma_1(0)##. Fie ##\tilde{\gamma}_0## and ##\tilde{\gamma}_1## be the continuous functions mapping [0,1] to X such that ##\tilde{\gamma}_j(0) = x_0## and ##p \circ \tilde{\gamma}_j = \gamma_j## for ##j = 0, 1##. If ##\gamma_0## and ##\gamma_1## are path-homotopic then ##\tilde{\gamma}_0(1) = \tilde{\gamma}_1(1)##.
Theorem 2
Suppose that ##p:X \to Y## is a covering map, ##D## is a path-connected, locally path-connected and simply connected topological space and ##f:D \to Y## is continuous. Suppose that ##a \in D##. Fix ##x_0 \in X## with ##p(x_0) = f(a)##. There exists a unique continuous function ##\tilde{f} : D \to X## such that ##f(a) = x_0## and ##p \circ \tilde{f} = f##.
I don't understand very well the proof of Theorem 2:
Given ##b \in D##, let ##\gamma:[0,1] \to D## be continuous with ##\gamma(0) = a## and ##\gamma(1) = b##. Let ##\tilde{\gamma}## be a lifting of ##f \circ \gamma## with ##\tilde{\gamma}(0) = x_0##.
Ok. Until there I understand that he constructs the unique path-lifting.
Define ##\tilde{f}(b) = \tilde{\gamma}(1)##. Since ##D## is simply connected, Theorem 1 shows that ##f## is well defined.
Here I don't understand anything. If you can help me to understand.. from where is that ##\tilde{f}## function already defined? Thanks!
The conditions of Theorem 2 require that (1) there exists a path between any two points of D (ie. a continuous \gamma: [0,1] \to D such that \gamma(0) is one of the two points and \gamma(1) is the other) and (2) that any two paths in D between those points are path-homotopic.
Since the continuous images of path-homotopic paths are path-homotopic, it follows that if \gamma' : [0,1] \to D is another path with \gamma'(0) = a and \gamma'(1) = b then f \circ \gamma and f \circ \gamma' are path-homotopic, so that by Theorem 1 the end points of the lifts of these paths are the same; this value therefore does not depend on the specific choice of path in D from a to b but only on the end point b. Thus the definition \tilde f(b) \equiv \tilde{\gamma}(1) makes sense: it doesn't depend on \gamma, but only on the fact that \gamma(0) = a and \gamma(1) = b. Since we are guaranteed that there will exist a path from a to any point in D and that any two such paths are path-homotopic, in this way we can define a function on the whole of D.
  • Care
Likes MathLearner123
@mathlearner: Use that simply-connectedness of ## D## (asumed in the problem) implies that ## \pi_1(D)=\{e\} ##, i.e., trivial. This means any two paths in ##D## are homotopically equivalent. Basically, there is one path between two points up to homotopy.
  • Care
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
