Question about light and relativity
In summary, the theory of relativity is based on the constant speed of light in the direction it is perceived to be traveling. This raises a question about the role of optical perspective in relativity. As the light clock moves farther away from the observer, the perceived distance it travels decreases, potentially affecting the ticking rate of the clock. However, in reality, optical perspective is an illusion and not a factor in special relativity. The concept of "seeing" in relativity refers to detecting light signals that have left a luminous object at different times, and the light clock measures a proper time interval while stationary clocks measure a non-proper time interval. There is further information available in a paper by the speaker on illustrating special relativity.
thunderchicken
Another question about light and relativity:
The way I “understand” the theory of relativity is that it is based on the fact that light always moves at a constant speed in the direction which you perceive it to be traveling. This is how (I think?) Einstein’s light-clock and spaceship analogy works.
My question is this: If relativity is based on the observer’s perception of light’s direction, does optical perspective (reality) have an effect?
As the light clock gets farther and farther away from the observer, the distance the light is traveling appears to decrease dramatically until it eventually disappears. If the perceived vertical distance the light has to travel becomes shorter, and light continued to travel at the same speed as always, would the clock not tick faster and faster the farther away it gets?
It seems to me that the thought experiment only works if the two clocks can be perceived as being exactly equal in height – something that is simply not possible. In reality, shouldn’t the person the spaceship age way faster??
Thanks for your help.
Optical perspective is an illusion, not a reality.
So, what would the observer see then as the clock moves away?
in special relativity to "see" means to detect at the same time light signals that have left a luminous object at different times. special relativity is involved with many clocks. The light clock you have singled out measures a proper time interval whereas the stationary clocks it meets during its trip measure by the difference between theirs readings a non-
I think you should rephrase your question. Please have a look at a paper of mine "Illustrating Einstein's special relativity" arxiv phyhsics education 2005.
FAQ: Question about light and relativity
What is the speed of light?
The speed of light is approximately 299,792,458 meters per second in a vacuum. This is considered to be the maximum speed at which all matter and information can travel in the universe.
How does light behave?
Light behaves as both a particle and a wave, depending on the experiment or observation. It travels in a straight line and can be reflected, refracted, or diffracted.
What is the theory of relativity?
The theory of relativity, proposed by Albert Einstein, states that the laws of physics are the same for all observers in uniform motion and that the speed of light is constant for all observers. It is divided into two parts: special relativity and general relativity.
What is the relationship between light and time?
According to the theory of relativity, the speed of light is constant for all observers regardless of their relative motion. This means that time can appear to pass differently for different observers depending on their relative speeds.
How does the theory of relativity affect our understanding of the universe?
The theory of relativity has revolutionized our understanding of the universe by changing our understanding of space, time, and gravity. It has also led to the development of technologies such as GPS and nuclear energy.
