Question about light emission.
In summary, in the Aharonov-Bohm effect, charged particles do not have to be deflected for the interesting part of the effect. In order to emit light, the particles need to be accelerated, typically through an electric or magnetic field, and high-energy particles and special magnetic fields are required for visible light emission.
cragar
2,552
In the Aharonov–Bohm effect when charged particles are deflected do they emit light?
Science news on Phys.org
They don't have to be deflected - at least not for the interesting part of the effect.
If charged particles are deflected, they emit electromagnetic waves. To get visible light, you need very high-energetic particles and special magnetic fields.
so I can get an electron to emit light even if its not in a B or E field.
I don't believe so. I think MFB was referring to the fact that in the Aharonov-Bohm experiment the charged particles don't have to be deflected in order for the interference to be shifted. To get a charged particle to emit light you need to accelerate it somehow, such as with an electric or magnetic field. If there is no acceleration then there is no light emission.
The Aharonov-Bohm effect is a quantum phenomenon that describes the interference of charged particles in the presence of a magnetic field, even when the particles do not directly interact with the field. This effect has been extensively studied and has been observed in various experimental setups.
In regards to the question about light emission, it is important to note that the Aharonov-Bohm effect does not directly involve the emission of light. Instead, it is a result of the quantum mechanical nature of charged particles and their interaction with a magnetic field. Therefore, it is unlikely that light emission would occur as a direct result of the Aharonov-Bohm effect.
However, it is possible that in certain experimental setups, the deflection of charged particles could lead to secondary effects that could result in the emission of light. For example, if the charged particles are accelerated or collide with other particles due to the magnetic field, it is possible that this could result in the emission of light. However, this would not be a direct consequence of the Aharonov-Bohm effect itself.
In conclusion, while the Aharonov-Bohm effect does not directly involve the emission of light, it is possible that in certain experimental setups, secondary effects may result in light emission. Further research and experimentation would be needed to fully understand the relationship between the Aharonov-Bohm effect and light emission.
Related to Question about light emission.
1. What is light emission?
Light emission refers to the process by which light is produced or given off by an object. This can occur naturally, such as the sun emitting light, or artificially, such as a light bulb emitting light when turned on.
2. What causes light emission?
Light emission is caused by the movement of particles, such as electrons, within an object. When these particles are excited, they release energy in the form of light. This can occur due to heat, electricity, or other forms of energy.
3. How does light emission work?
Light emission works through a process called photon emission. When particles, such as electrons, gain energy, they move to a higher energy level. As they return to their original energy level, they release energy in the form of photons, which are particles of light.
4. What are some examples of light emission?
Some examples of light emission include the sun emitting light, a fire emitting light and heat, a light bulb emitting light when turned on, and a glow stick emitting light when cracked.
5. What are the practical applications of light emission?
Light emission has numerous practical applications in our daily lives. It is used in lighting, communication systems, medical imaging, and many other fields. It also plays a crucial role in photosynthesis, which is the process by which plants convert light energy into chemical energy.
  • Optics
  • Electromagnetism
  • Optics
