Question about light waves and phases.
In summary, the conversation discusses the theory of destructive interference and how it applies to both sound and light waves. It is possible to cancel out sound and light by having two identical sources with one being 180 degrees out of phase with the other. However, this is more difficult to achieve with light due to its shorter wavelength. Examples of anti-resonance and applications of this phenomenon in optical devices are also mentioned.
andrewbob
I am a sound tech and I no from my work there that if you have (in theory) two sound waves and 1 is 180 degrees out of phase with the other that they will cancel each other out. - This is mainly the basic theory of noise canceling headphones (along with some acoustic material, etc) and balanced mic leads.
But if we model light as waves does that then mean that if there was two identical sources of light (same wave length, amplitude, etc) but one was 180 degrees out of phase with the other would that appear to produce no light at all?
Just a thought, that no one seems to be able to tell me the answer to. Maybe I'm missing some information somewhere along the track.
Any thoughts?
Thanks
Andrew Bob
Science news on Phys.org
You are correct. The phenomenon is known as destructive interference, and works for light as well as sound.
Would it be possible to build such a light?
So that you could have them on side stage constantly changing to the lighting conditions on stage and just keep canceling out the light? Like noise canceling headphones?
Or is this where the real world starts to make theory's stop working?
Andrew Bob
The difference here is that sound has a significantly longer wavelength than light. So you can make sound to have a region of "destructive interference" larger than sound. It is not possible with light because, if you have seen the pattern from a 2-slit experiment, you'll notice that in the visible range, the region where such destructive interference occur is VERY small.
Zz.
Yup. There are a number of phenomena that demonstrate it.
IIRC, The "anti-reflection" coating on monitors and camera lenses is a transparent film that is a half a wavelength in thickness. Light from the outside (the glare) bounces off both the initial (outer) surface of the film, as well as off the inner surface (or maybe it's the outer surface of the glass that it's coating ... whatever). You can then treat the different reflections as if they were "identical sources of light (same wave length, amplitude, etc)". Since the second reflection is 180 degrees out of phase with the first reflection, it cancels out. Of course, that "half wavelength" is only true for the middle of the visible spectrum, so the upper and lower visible frequencies are still visible in the reflection, hence the blue and red appearance of the anti-reflection coating.
Oil slicks on water also produce their rainbow effect in a similar way. The different colours come about due to slight variations in the film thickness, so that different wavelengths of light are canceled out in different atreas of the oil slick
Just for laffs, see also http://en.wikipedia.org/wiki/Double-slit_experiment .
Andrew Bob
One way to demonstrate destructive interference at optical freqs is to use a laser to get a monochronic source. Then send your monochronic beam to a double slit which will act like two sources of the same light in phase. The result will be an interference pattern where the light will alternately interfere constuctively (bright bar) and destructively (dark bar). The analog in sound would be to have a sound of a single note coming from two speakers properly spaced and in phase. Walk across in front and hear the intensity rise and fall alternately.
Absolutely, the phenomenon you describe is called anti-resonance. The common example of this is in Planish's example of anti-reflection coatings. In this case the two sources comprise of a transmitted beam and a twice-reflected beam which are out of phase by 180 degrees. This results in suppression of the "sources" which manifest as strong reflection.
You can get meta-materials called photonic crystals that behave in much the same way as anti-reflection coatings, but in multiple directions. It is possible to get anti-resonance to occur in 2 and even 3 dimensions. Sources embedded in such crystals have their emission suppressed at a wavelength determined by the dimensions of the photonic crystal.
Far from being a mere curiosity, this behaviour is used to make many interesting optical devices, including endlessly single-mode fibre, superprisms and integrated photonics.
Claude.
Related to Question about light waves and phases.
1. What are light waves?
Light waves are electromagnetic waves that are part of the electromagnetic spectrum. They are a form of energy that can travel through empty space or through a medium, such as air or water.
2. What are the different phases of light waves?
The different phases of light waves are the different regions of the electromagnetic spectrum. These include radio waves, microwaves, infrared, visible light, ultraviolet, x-rays, and gamma rays.
3. How do light waves behave?
Light waves behave like waves, exhibiting properties such as reflection, refraction, and interference. They can also behave like particles, which is known as the particle-wave duality of light.
4. What is the speed of light?
The speed of light is approximately 299,792,458 meters per second in a vacuum. This is the fastest speed at which anything in the universe can travel.
5. How are light waves measured?
Light waves are measured in terms of their wavelength and frequency. Wavelength is the distance between two consecutive peaks or troughs of a wave, while frequency is the number of waves that pass a given point in one second. The unit for wavelength is meters, and the unit for frequency is hertz (Hz).
11K
  • Electrical Engineering
