Question about Magnetic Circuits in a Transformer Core
In summary, according to the answer in the Instructor's Manual for part (a) of the problem 1.13, the total magnetic flux across the leg is found by taking the sum of the magnetic fluxes in the two outer loops, which is equivalent to taking the magnetizing intensity on the center loop and adding it to the magnetizing intensity on each of the two outer loops.
Paola Flores
Hello community,
I can't find an explanation for something and I thought I'd come and ask you.
I'm studying for a test I have tomorrow and I came across a problem of a three legged steel core with 400 turns on the center leg, the magnetization curve is given, the first part of the problem asks you to find the current required to produce a certain flux density in the central leg of the core.
So what I did was to first find the magnetic flux across the leg.
Φcenter=B.Across
Then because the two outer legs are symmetric, I found their magnetic flux by dividing the one coming from the center leg, and found the flux density on each outer leg with this information.
B=Φouter/(Across
But then, when trying to find the MMF, for me, it would be the MMF required to produce that magnetizing intensity on the center leg plus the magnetizing intensity on each outer leg so what I did was:
Ftotal=H*lcenter+H*louter*2
but checking the Instructor's manual, it only takes in consideration the magnetizing intensity for the center and one leg (one magnetic loop):
I guess it's because of the analogy with electric circuits when they are in parallel, but I'm not sure, so I was wondering why is it we only take one of the outer legs in consideration, instead of the two of them to find the total MMF.
Can anybody enlighten me? I'd appreciate it! Thanks in advance!
The problem is 1.13 in Chapman Electric Machinery
https://imgur.com/a/PD8A7xQ
The way I would work this problem is to write ## \oint H \cdot dl=NI ## for the loop that goes through the center and around the right side, and also the same equation for a loop that goes through the center and around the left side. You can assign ## H_1 ## to the center, ## H_2 ## to the right, and ## H_3 ## to the left. (## H_2 ## and ## H_3 ## are the values of ## H ## in the integral once the path of the loop leaves the center leg). Meanwhile, by symmetry ## H_2=H_3 ##. Since the thickness is 8 cm everywhere it simplifies the ## B ## computation: You can work with ## B ## instead of flux ## \Phi ##. Let ## B_1 ## be the magnetic field in the center leg. ## B_1=B_2 +B_3 ## by flux conservation. Writing ## B_1=\mu H_1 ##, ##B_2=\mu H_2 ## and ## B_3=\mu H_3 ## makes it simply an algebraic exercise. I'll leave the calculation to you, and see if it agrees with the answer that they give. ## \\ ## Upon further study of it, I see that all of the ## \mu's ## are not equal. The center ## \mu ## will be different from the ## \mu's ## in the outer legs. I think the problem may require having an equation for ## \mu ## as a function of ## H ## for a complete solution, but I am going to need to study it further. ## \\ ## Additional editing: I studied their solution to part (a) and it makes sense. ## \\ ## And I think I see what your question is: The way the equation ## \oint H \cdot dl=NI ## works is you just take the integral around a single loop in the transformer. ## \\ ## It might interest you that the equation ## \oint H \cdot dl =NI ## is actually a form of Ampere's law ## \oint B \cdot dl=\mu_o I ## when magnetic materials are involved. Beginning with the equation ## \nabla \times B=\mu_o J_{total} ## where ## J_{total}=J_{free}+J_m ##, (## J_{free} ## is current density of any currents in conductors, and ## J_m ## is magnetization current density to to variations in the magnetization ## M ##), and also writing ## B=\mu_o H+M ##, we can take the curl of both sides of this last equation, and we get ## \nabla \times B=\mu_o \nabla \times H+\nabla \times M ##. An in-depth analysis shows that ## \nabla \times M=\mu_o J_m ## so that ## \nabla \times H=J_{free} ##. Integrating over an area ## dA ## and applying Stokes' theorem to this result and including a number of turns factor gives the result ## \oint H \cdot dl =NI ##. ## \\ ## This last part is some theoretical detail, but you might find it of interest that the application here with the MMF formula is really just an extension of the same concept of using loop integrals for calculating magnetic fields using Ampere's law. The equation ## \oint H \cdot dl=NI ## is a modified form of the integral form of Ampere's law that is used when magnetic materials are involved.
Likes jim hardy and Paola Flores
You're exactly right.
Likes Paola Flores
Yes, I realized this after some more reading. I had the test on Thursday and there even was a problem that involved infinite permeability (zero reluctance) and that part of the core behaved like a "short circuit". I'm amazed at how Kirchhoff and Ohm's Laws apply so satisfactorily with magnetism as well.
Likes jim hardy
This was sort of another -more theoretical- way to put it, but it actually was a very good way to understand why magnetic circuits are analyzed this way taking only one magnetic loop in consideration. Thank you.
PD. I admire your knowledge in magnetism.
Likes Charles Link
They work fine for most of what you'll need to do.
Reluctance is a function of B and that's why the B-H graph is a curve not a straight line.
We usually handle that graphically .
Just remain aware we do basic magnetic design work with approximations, graphs and tables that let us reduce the math to algebra.
Maxwell's equations are elegant
if perhaps overkill for an introduction to electric machinery. .
but will become part of your repertoire.
Glad it "clicked" for you.
Likes Charles Link
Related to Question about Magnetic Circuits in a Transformer Core
1. How does a transformer core work?
A transformer core is made up of a highly conductive material, such as iron or steel, that is wound with coils of wire. When an alternating current (AC) is passed through the primary coil, it creates a changing magnetic field. This changing magnetic field then induces a current in the secondary coil, which results in the transfer of energy from one circuit to another.
2. What is the purpose of a transformer core?
The main purpose of a transformer core is to provide a path for the magnetic flux generated by the primary coil. This allows the energy to be transferred efficiently from the primary to the secondary coil without significant losses. Additionally, the core also helps to concentrate the magnetic flux, making the transformer more compact and efficient.
3. How is the magnetic circuit in a transformer core designed?
The design of a magnetic circuit in a transformer core involves selecting the appropriate core material, determining the number of turns in the coil, and determining the physical dimensions of the core. This process is based on the desired voltage and current levels of the transformer and the frequency of the AC input.
4. What factors affect the magnetic circuit in a transformer core?
The magnetic circuit in a transformer core is affected by various factors such as the type and quality of the core material, the number of turns in the coils, the physical dimensions of the core, and the frequency of the AC input. Changes in any of these factors can impact the efficiency and performance of the transformer.
5. How can the efficiency of a transformer core be improved?
The efficiency of a transformer core can be improved by selecting a core material with high magnetic permeability, minimizing the air gaps in the core, and using specialized winding techniques to reduce losses. It is also important to properly design and maintain the transformer to ensure it is operating at its optimal efficiency.
  • Electrical Engineering
10K
