Question about Maxwell's Equations
In summary: Essentially, what you're saying is that if you have an equation that talks about electric and magnetic fields, and another equation that talks about flux, then you can use the divergence of the two equations to get a third equation that talks about EMF.
lugita15
1,556
Is it possible to derive Faraday's Law from the other three Maxwell equations plus the conservation of charge? If so, how?
Any help would be greatly appreciated.
Thank You in Advance.
Conservation of charge is not related to Faraday's law in any way, since Faraday's Law has absolutely nothing to do with charge. Faraday's law only talks about fields.
Faraday's Law cannot be derived from the other equations. If it could, it wouldn't be considered one of Maxwell's equations.
If you take the divergence of Maxwell's curl H equation, you get the continuity equation, which is equivalent to conservation of charge (if you use the div D equation). But you can't go the other way, although that is probably how Max deduced the D dot term.
You can go the other way, to some extent.
1. Start with the curl H equation with only the j term on the right.
2. Take the divergence of both sides.
3. This gives div j=0, but div j =-d rho/dt.
4. This requires adding the d D/dt term (using the div D Maxwell eq.) , which is equivalent to Farady's law.
How is that equivalent to Faraday's law? Faraday's law relates d B/dt to curl E, not d E/dt to curl B. Doesn't it? :confused:
My understanding is this: despite their mathematically rigorous statements, Maxwell's Equations are all empirical laws, meaning that they can't be derived by any axiomatic approach. As such, the only way to "derive" Faraday's Law would be to do a physical experiment and deduce it. In this case, you'd need to alter the magnetic flux of a conducting loop, and show that the line integral of the electric field (=the EMF) is equal to the rate of change of flux through the loop. But since each of Maxwell's equations say different things about the electric and magnetic fields, I can't think of a way in which you could derive any of them from the others.
Yes, I just got careless.
FAQ: Question about Maxwell's Equations
What are Maxwell's Equations?
Maxwell's Equations are a set of four equations that describe the fundamental relationship between electric and magnetic fields. They were developed by James Clerk Maxwell in the 19th century and are considered one of the cornerstones of modern physics.
What is the significance of Maxwell's Equations?
Maxwell's Equations are significant because they unify the previously separate theories of electricity and magnetism into a single framework. They also led to the discovery of electromagnetic waves, which are responsible for many modern technologies such as radio, television, and wireless communication.
What are the four equations in Maxwell's Equations?
The four equations in Maxwell's Equations are Gauss's Law, Gauss's Law for Magnetism, Faraday's Law, and Ampere's Law. Together, these equations describe how electric and magnetic fields interact with each other and with charged particles.
How are Maxwell's Equations used in real-world applications?
Maxwell's Equations are used extensively in many areas of science and engineering, including telecommunications, electronics, and optics. They are also crucial for understanding the behavior of electromagnetic waves, which are used in technologies such as radar, MRI machines, and satellite communications.
Are there any limitations to Maxwell's Equations?
While Maxwell's Equations accurately describe the behavior of electric and magnetic fields in most situations, they do not account for certain phenomena such as quantum effects and the behavior of materials at the atomic scale. In these cases, more advanced theories, such as quantum electrodynamics, are needed to fully explain the behavior of electromagnetic fields.
