Question about Multimeters
  • Thread starter AchillesWrathfulLove
In summary, the multimeter has a dial that allows you to measure voltage and current, but you should not leave the probes in the current measurement jack, and you should take a $15-20 fuse to repair the meter if it breaks.
30
Ideally does a perfect multimeter have infinite resistance when testing current and voltage?
AchillesWrathfulLove said:
current and voltage
"And?" Think for a moment about the definitions.
Ok so Voltage is potential difference between two points and current is flow of charge... so you would want ideally infinite resistance to test the current but maybe no resistance at all when testing voltage? Is this correct, I correct my mistake?
Bystander said:
"And?"
Multimeters went by a different name when I was a kid.
Did you mean voltmeters? as that's what they were most often used for.
I recently had to get a new one and discovered the analog varieties can be quite pricey and that the digital ones look real cheesy. I eventually decided on a Triplett for $30 bucks at Fry's Electronics. The multimeter dial seems a little wonky though it appears to act like a push button switch but I couldn't figure out what it did if anything. Also when I tested continuity I discovered my hearing is so bad I could hear the beep until I had the meter next to my ear.
My two earlier meters were Radio Shack meters and they were excellent. My favorite was an analog meter, my first, I had in high school. It hurt when a friend borrowed it and dropped it, breaking the glass over the meter. Later I got an LCD one that worked well until the LCD turned brownish thru 30+ years of aging I guess.
I can't attest to their quality, only their existence. Harbor Freight has them available starting at single-digit pricing. Search for 'multimeter' on their site.
Cheers,
Tom
Likes jedishrfu
Suppose you needed to test the voltage of your car battery, so connected the multimeter between the battery's red and black terminals. Would you like the battery to sense that you were connecting zero ohms or infinite ohms between its terminals to make this measurement?
Ok so other way around I think
Likes CWatters
Correct. You want infinite resistance on the voltage ranges to avoid loading the voltage source. Some meters use the gate of a FET to achieve this.
You want zero resistance on the current ranges so you don't increase the resistance in the circuit an change the current you are trying to measure.
Tip: Before putting your meter away always set it to a high voltage range.
Likes jedishrfu
... and ensure the probes are not left in the current measurement jacks.
Likes jedishrfu and CWatters
I knew them as VOMs,
https://en.wikipedia.org/wiki/Multimeter said:
A multimeter or a multitester, also known as a VOM (volt-ohm-milliammeter) ...
Forgot this on my Fluke recently They take a $15 - $20 fuse to repair. (And it is a 400mA fuse... Unfortunately my last current measurement was 500mA)
Even more dangerous is that some don't have a fuse at all.
BoB
I still have a meter that let smoke out when it was connected to a battery while set on the 10A current range by accident
I met them as AVO meters. Whether the AVO was a clever bit of branding, or just a fortuitous coincidence, I don't know.
Likes dlgoff
actually for most multimeters these days, don't do that, switch (rotate) to off to stop battery going flat :wink:
granted, there are those that have a separate on/off button and since most are auto ranging these days
just setting to voltage position is a good idea :smile:
Likes CWatters and dlgoff
FAQ: Question about Multimeters
How does a multimeter work?
A multimeter works by measuring electrical voltage, current, and resistance. It has two probes that are used to make contact with a circuit or device, and then displays the measurement on a digital screen.
What are the different types of multimeters?
There are three main types of multimeters: analog, digital, and auto-ranging. Analog multimeters use a needle to display the measurement, while digital multimeters have a digital screen. Auto-ranging multimeters can automatically select the appropriate range for the measurement being taken.
How do I use a multimeter to measure voltage?
To measure voltage, set the multimeter to the voltage setting and then connect the probes to the circuit or device. The red probe should be connected to the positive side and the black probe to the negative side. The multimeter will then display the voltage reading.
Can a multimeter measure both AC and DC voltage?
Yes, most multimeters have the ability to measure both AC (alternating current) and DC (direct current) voltage. Make sure to set the multimeter to the appropriate setting before taking a measurement.
What is the difference between continuity and resistance on a multimeter?
Continuity is a measurement that determines if there is a complete path for electricity to flow, while resistance measures how much a material resists the flow of electricity. Continuity is usually measured in ohms, while resistance can be measured in ohms or kilohms.
