Prishon
- 50
- 8
There are n vertical identical parallel identical cilinders rotating around their length axes with the same angular velocity. The are somehow fixed wrt to Earth and brought together (on a rail?). After the contact there is no slipping and the cilinders are coupled to their neighbor cilinders. It is easy to see the cilinders end up as follows:
For even n there is no rotation anymore. All cilinders are at rest.
For uneven n the cilinders end up with contrary velocities. If there are n cilinders in contact then the absolute value of their angular velocities will be 1/n of the initial value.
For example, 3 cilinders (assuming their mass and initial angular velocities are 1) end up with angular momentum 1/3 and kinetic energy of 1/9 of the initial value.
But how is the energy dissipated? 1/9 of the momentum and energy are left in the cilinders. The rest of the momentum has flown into Earth. But where has the energy gone. Not into the Earth(well a very small part). Has it gone by friction? But what if the cilinders were toothwheels?
