B Question about Neon-burning Process
In the neon-burning process in stars, two Neon-20 atoms do not fuse directly into Calcium-40 due to the sequence of reactions involved. Initially, Neon-20 undergoes photodisintegration, producing Oxygen-16 and an alpha particle. Under high temperatures, the alpha particle is captured by another Neon-20 nucleus, resulting in Magnesium-24 and releasing gamma radiation. This process requires two Neon nuclei: one to provide the alpha particle and another to absorb it, rather than a direct collision of two Neons. The overall reaction yields Oxygen-16 and Magnesium-24, along with energy.
DrLich
During the neon-burning process in stars, why do two Neon-20 atoms fuse into Oxygen-16 and Magnesium-24 instead of forming Calcium-40?
Astronomy news on Phys.org
The 2Ne20->O16+Mg24+energy reaction is the nett result. It's actually two reactions.
First, neon is photodisintegrated into oxygen and an alpha particle:
Ne20+gamma->O16+He4
Normally the reverse reaction would occur, keeping the neon stock steady. But with sufficient temperature, alpha capture by another neon nucleus is preferred:
Ne20+He4->Mg24+gamma
So you need two neon nuclei, one to donate the alpha particle, the other to subsequently absorb it. It's not that the two neons collide, and two other nuclei pop out.
See e.g. here:
https://iopscience.iop.org/article/10.1088/0004-637X/797/2/83
Likes Astronuc, Klystron and Baluncore
Ne20+gamma->O16+He4
See e.g. here:
Thank you very much!
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
