Question about net work and displacement
In summary, the conversation discusses the relationship between displacement, work, and kinetic energy in various scenarios. It is stated that if displacement is zero, work is also zero according to the definition for a constant force. However, the general formula for work is an integral that is path-dependent. This means that for a non-constant or non-conservative force, the total work may not be zero even if displacement is zero.
FQVBSina_Jesse
54
I know that by physics definition if displacement is zero, work is zero.
However, if I push an object 5 m to the east, and then move to the other side of the object and push it 5 m back to the west. I think in this case I have always done positive work on the object and hence the total work done shouldn't be zero.
If I swing the object around in a circle then my force is perpendicular, so the work done is zero, but what about if I pushed a cart around in a circle from behind?
When it stopped moving on each leg, which way was the force that stopped it pointing?
Stopped by friction. As in if I stop pushing then it doesn't move. And friction points in the opposite direction. But friction is a dissipative force
So the total work done by friction has the opposite sign to the work you did. What's the magnitude of the work it did compared to the work you did?
Ibix said:
So the total work done by friction has the opposite sign to the work you did. What's the magnitude of the work it fid compared to the work you did?
Ok, I still don't know why you are asking about friction since friction would just be calculated into the net force. But the friction's work would be whatever the friction force is times the total distance (not displacement since friction is not conservative), which will be less than the pushing force.
So you are saying that you do work on the object, implying that it gains kinetic energy. And the frictional force does work of the opposite sign and a smaller magnitude. So the object is left with kinetic energy - it hasn't stopped. How are you going to stop it?
I am going to stop pushing on it so the friction dissipates the energy and it stops. Then I move to the other side and push the object back.
Right. So the frictional force does the same magnitude of work as you do, but with the opposite sign. So the total work on the object is?
The total work is (myforce - friction) x 5 + (myforce - friction) x 5
This is not a general definition, it is only the definition for the specific case of a constant force. In your description the force is not constant.
The general formula is ##W=\int_S F \cdot ds ##
Likes FQVBSina_Jesse
There we go! This is what I was looking for. Work integral is path dependent. Thanks!
Likes Delta2 and Dale
And that is? (Hint: it starts with zero kinetic energy, it ends with zero kinetic energy - what's the change in energy?)
Not only for constant force but for a conservative force, the total work is zero if the total displacement is zero. This is a consequence of the definition of the conservative force and the definition of work and the gradient theorem.
In the general case a force might not be conservative, the gradient theorem cannot be applied, so the work becomes path-dependent,so the total work is not necessarily zero even if the total displacement is zero.
Related to Question about net work and displacement
1. What is net work?
Net work is the total amount of energy transferred to or from an object due to the application of a force over a certain distance. It is a measure of the change in an object's kinetic energy.
2. How is net work calculated?
Net work is calculated by multiplying the magnitude of the force applied to an object by the distance the object moves in the direction of the force. This can be represented by the equation W = Fd, where W is net work, F is force, and d is distance.
3. What is displacement?
Displacement is the change in an object's position or location. It is a vector quantity, meaning it has both magnitude and direction. It is typically measured from an object's starting point to its ending point.
4. How is displacement related to net work?
Displacement is related to net work because it is the distance over which the force is applied. The direction of displacement also affects the direction of net work. For example, if the force and displacement are in the same direction, the net work will be positive. If they are in opposite directions, the net work will be negative.
5. What is the difference between net work and displacement?
The main difference between net work and displacement is that net work is a measure of the energy transfer due to a force, while displacement is a measure of the change in an object's position. Net work is a scalar quantity, while displacement is a vector quantity. Additionally, net work takes into account the direction of the force, while displacement only considers the overall change in position.
  • Mechanics
  • Mechanics
