Question about nucleotides and phosphoric acid
  • Thread starter Thread starter physicisttobe
    Acid
Phosphoric acid is correctly linked to sugars through ester bonds, not ether bonds, as the original statement suggested. The confusion arises from the terminology, as esters are formed through the dehydration of a hydroxyl group, which no longer exists after the reaction. The discussion clarifies that while the term "linked" is commonly used, it may not accurately represent the chemical process involved. Participants agree that the distinction between ether and ester bonds is important for clarity. Accurate terminology is essential in biochemical discussions to avoid misunderstandings.
physicisttobe
Misplaced Schoolwork Thread -- Moved to the Schoolwork forums
Hi everyone!
Is this sentence correct?
"Phosphoric acid is linked to the hydroxyl groups of the sugars via ether bonds"
I would say yes, but in the solutions this phrase is wrong and I'm a little bit confused. I think that's correct, isn't it?
Technically they’re esters. An ester is any linkage that has been formed through a hydroxyl by loss of a water molecule. The most familiar example is carboxylic esters, but in this case you have a phosphoric ester. In really old literature, you’ll occasionally see alkyl halides referred to as halide esters (e.g., butyl iodide would be butane hydriodic ester), reflecting the idea that they're formed from the dehydration reaction of the hydrogen halide with an alcohol.
Likes pinball1970
All right, thank you for your reply TeethWhitener!
So instead of ether bond there must be an ester bond, then it's correct.
I have mixed up the two.
Perhaps that's nitpicking, but I don't like the idea of "being linked to the hydroxyl group". Hydroxyl group reacted and no longer exists, so nothing can be linked to it.
All right, thanks borek!
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
