Question about objects rolling on a incline plane
In summary, the conversation discusses a problem from an AP Physics rotation test involving a ball on a U-shaped track. The left half of the track is frictionless and the right half has friction. The question asks for the maximum height the ball will reach on the left side. The conversation also mentions equations and attempts at a solution, including the conservation of energy. It is determined that if the ball starts on the left, it will reach the same maximum height on the right, but if it starts on the right, it will not reach the same height.
r1p4c3
Before I start the problem, I would like to apologize for not using the formating. I am posting this from my high school's network and they have an absurd filtering algorithm that blocks css and other web scripts so I can't use the normal formatting since I can't remember the format tags for vBulletin.
This problem is from my AP Physics rotation test, and of my peers that I talked to, we can't agree what the answer is.
A ball of uniform density is placed at the top of the left side of a U shaped track. The left half of the track is friction less and the right half has friction. The top of the track is a height h above the bottom of the track. The ball has a mass of m and a radius of r.
What is the maximum height the ball will reach on the left side??
v = r x w
I = 2/5 m*r^2
GPE = mgh
KE = 1/2 m*v^2 + 1/2 I*w^2
Energy is conserved throughout the path of the ball. Since the left half of the track is friction less, so it won't roll but slide.
GPE = KE ==> mgh = 1/2 m*(v0)^2 ==> v0 = sqrt(2gh)
Energy before entering the friction part should be the same after entering it.
1/2 m*(v0)^2 = 1/2 m*v^2 + 1/2 I*w^2 ==> 1/2 m*(v0)^2 = 7/5 m*v^2 ==> v = (v0)*sqrt(5/7) = sqr (10gh/7)
Finally, energy is conserved while it rolls up the right side
1/2 m*v^2 + 1/2 I*w^2 = mgh
7/10 m*v^2 = mgh
7/10 v^2 = gh
h = 7/(5g) v^2 = 7/5g * 10gh/7 = h
The math says the final height will be the same as the initial height, but that answer seems too simple for this question.
Edit: I pressed submit too early. Is the math and assumptions I posted correct? ?
What would happen if the ball were released from the top of the right side?
Wont friction do some work in stopping the object and hence some energy would be lost ?? :confused: Can conservation of energy be applied ??
No, if the ball is rolling without sliding there will be no loss of energy. Your "v0" is the speed of the ball at the bottom of the track, right? You should say that. Yes, at the bottom of the track, after sliding down the frictionless side, all potential energy will have been converted to kinetic energy. As soon as it starts up the right side, where there is enough friction to cause the ball to roll, potential energy will be converted to both the linear kinetic energy of its forward motion and the rolling energy. However, when the ball stops both its linear kinetic energy and its rolling energy will be 0 so all energy will have been converted back to potential energy. It will now have the same potential energy as initially so will have the same height.
The situation is different if the ball starts on the right, from the same height, of course. As the ball goes down the right side, it will gain both linear kinetic energy and rolling energy. At the bottom, its linear kinetic energy will not be much as as before because only part of the potential energy will have been converted to linear kinetic energy. As the ball goes up the right side, there will be NO friction to stop the rolling so the ball will go up until its linear kinetic energy has been converted back to potential energy so it will still be spinning even after it has stopped going up. Since only part of the initial potential energy has been converted back to potential energy, the ball will not go as high on the right.
Your math and assumptions are correct. The fact that the final height is the same as the initial height may seem too simple, but it is a result of energy conservation. As the ball rolls down the left side of the track, its potential energy is converted into kinetic energy. When it reaches the bottom of the track, all of its potential energy has been converted into kinetic energy. As it rolls up the right side of the track, its kinetic energy is converted back into potential energy until it reaches the same height as it started. This is a fundamental concept in physics known as the conservation of energy.
FAQ: Question about objects rolling on a incline plane
What is an inclined plane?
An inclined plane is a flat surface that is angled or sloped. It is often used to make it easier to move heavy objects by reducing the amount of force needed to lift or move the object.
How does an inclined plane affect the motion of rolling objects?
An inclined plane can change the motion of rolling objects by altering the direction and speed of the object. When a rolling object moves up an inclined plane, its motion will slow down due to gravity. When it moves down an inclined plane, its motion will speed up due to gravity.
What forces act on a rolling object on an inclined plane?
The forces acting on a rolling object on an inclined plane are the force of gravity pulling the object down the slope, and the normal force of the inclined plane pushing back on the object. Friction may also play a role in slowing down the motion of the object.
How does the angle of the inclined plane affect the motion of the rolling object?
The steeper the angle of the inclined plane, the greater the force of gravity acting on the object and the faster the object will accelerate down the plane. A shallower angle will result in a slower acceleration and less force of gravity acting on the object.
What is the relationship between the height and length of an inclined plane?
The height and length of an inclined plane are inversely related. As the height of the plane increases, the length of the plane needs to increase in order to maintain the same angle of inclination. This relationship allows for a longer distance for the object to roll, which can result in a more gradual change in speed and a smoother motion.
