I Question about orbital and spin magnetic dipole
In the discussion about orbital and spin magnetic dipoles, it is clarified that in diamagnetic substances, the spin dipole is indeed equal and opposite to the orbital dipole, resulting in an induced magnetic dipole that opposes an external magnetic field. Conversely, in paramagnetic substances, the combined effect of the spin and orbital dipoles does not cancel out, leading to a net magnetic moment that is greater than zero. The intrinsic magnetic moment of electron spin primarily influences diamagnetism, while the orbital path's magnetic moment is significant in paramagnetism. The interaction with an external magnetic field alters the orientation of these dipoles differently in each case. Understanding these principles is essential for grasping the behavior of materials under magnetic fields.
SR_0301
Hello guys, i want to ask you a question about orbital and spin dipole, and how this is going to influence diamagnetic or paramagnetic substances. So my question is: we know in a atom there is orbital and spin motion by electrons so possibly two magnetic dipoles. Is it correct to say that in diamagnetic substances, the spin dipole is equal and opposite to the orbital dipole, so when we provide a magnetic field we get induced magnetic dipole opposite to that magnetic field. And is it also correct to say that this is not going to show up in a paramegnetic substance because here spin dipole + orbital dipole is different from zero?
See The Magnetism of Matter
That is Chapter 34 in The Feynman Lectures on Physics, Volume II. The website is hosted by Cal Tech.
Magnetism in diamagnetic materials is dominated by the intrinsic magnetic momentum of the electron spin.
A B field acting on this magnetic moment rotates it in the direction of B, so that mu is greater then one.
Magnetism in a paramagnetic material is caused by the field acting on the magnetic moment of the electron's orbital path. By Lenz's law, this rotates the dipole moment away from the direction of the B field, so that mu is less then one.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
