Question about perimeter weighting in golf clubs
In summary: However, with perimeter weighting, the weight is distributed evenly, making it less likely for the head to twist during impact.
Duster22
From How Stuff Works:
"In the last 25 years, designers have developed clubs that have approximately the same weight as the older clubs but have it distributed around the perimeter of the club, so that the head is far more resistant to off-center twisting and therefore far more forgiving of golf swings that are off line by a few millimeters."
<http://entertainment.howstuffworks.com/sports/golf/basics/golf-club2.htm>
How does perimeter weighting cause the club head to twist less when shots are hit off centre?
I am also having trouble picturing what axis the head would be twisting around: if it rotates about the shaft then wouldn't the collision producing the least twisting occur right at the shaft (the heel of the clubhead)?
Thanks
!Perimeter weighting causes the club head to twist less when shots are hit off-center because it distributes the weight of the club around the perimeter of the head. This creates a more balanced structure that is less likely to twist when an off-center shot is hit. The axis that the head would be twisting around is the center of the shaft. The heel of the clubhead would be the furthest point from the center of the shaft, and therefore the most vulnerable to twisting.
FAQ: Question about perimeter weighting in golf clubs
What is perimeter weighting in golf clubs?
Perimeter weighting refers to the distribution of weight around the outer edges of a golf club head. This design feature is intended to increase the moment of inertia (MOI) of the club, making it more forgiving and reducing the effects of off-center hits.
How does perimeter weighting affect the performance of a golf club?
Perimeter weighting increases the MOI of a golf club, which helps to stabilize the club head and reduce twisting on off-center hits. This can result in more consistent and accurate shots, particularly for golfers with less consistent swings.
What types of golf clubs typically use perimeter weighting?
Perimeter weighting is commonly used in irons, particularly those designed for beginning or intermediate golfers. It may also be found in hybrid clubs and some drivers.
Are there any downsides to perimeter weighting in golf clubs?
While perimeter weighting can improve forgiveness and consistency, it can also reduce the feel and feedback of a golf club. Some golfers may prefer a more traditional club design that allows for more control and shot shaping.
Is perimeter weighting the only factor that affects the performance of a golf club?
No, there are many other design factors that can impact the performance of a golf club, such as the center of gravity, loft, and shaft flex. Perimeter weighting is just one aspect that can contribute to the overall performance of a club.
