Question about Polynomial Functions From Data
In summary, the conversation discussed a chart given by a teacher with X-Values ranging from 1 to m+2, and the question of what the m-2/m+2 stuff meant. It was clarified that m is just a variable and the functions being examined are y = x, y = x^2, and y = x^3. It was also mentioned that m can be treated as a constant or variable in this problem.
Rowah
My teacher gave me a chart to fill in that has X-Values that look like this:
x
m - 2
m - 1
m
m + 1
m + 2
My question: What the heck is that m - 2 / m + 2 stuff?
Above the chart he gave me, it says:
"Examine the following functions for the set of x-values
{1,2,3,4,..., m - 2, m - 1, m, m + 1, m + 2,...}
I have absolutely no idea what "m" is.. Can someone please lend me a hand?
x
m - 2
m - 1
m
m + 1
m + 2
im going to assume that m is just some variable??
what are the functions?? That would give more insight
i think the m is just to show what the function would look like if m-2 was plugged into it
The functions are: y = x, y = x^2, y = x^3
If that is the entirety of the problem, you can treat m as if it were some constant or variable.
Ok thanks waterchan, that's what my teacher said today :D
FAQ: Question about Polynomial Functions From Data
What is a polynomial function?
A polynomial function is a mathematical expression consisting of variables and coefficients, with the variables raised to non-negative integer powers. It can also be written as a sum of monomials, where each monomial is a single term with a coefficient and a variable raised to a power.
How do you determine the degree of a polynomial function?
The degree of a polynomial function is the highest power of the variable in the expression. For example, the polynomial function 3x^2 + 2x + 1 has a degree of 2, since the variable x is raised to the power of 2. The degree of a polynomial function can also be determined by counting the number of terms in the expression.
How do you graph a polynomial function from data?
To graph a polynomial function from data, you will need to plot the given data points on a coordinate plane. Then, use a ruler or a graphing calculator to draw a smooth curve that passes through all the data points. This curve represents the graph of the polynomial function.
What is the relationship between the degree of a polynomial function and the number of roots?
The degree of a polynomial function determines the maximum number of roots or solutions it can have. For example, a polynomial function of degree 2 can have a maximum of 2 solutions, while a polynomial function of degree 3 can have a maximum of 3 solutions. However, it is important to note that not all polynomial functions will have the maximum number of solutions.
How can polynomial functions be used to model real-world data?
Polynomial functions can be used to model real-world data by fitting a curve to the given data points. This curve can then be used to make predictions or estimate values for data that were not originally given. For example, a quadratic polynomial function can be used to model the trajectory of a ball thrown in the air, or a cubic polynomial function can be used to model the growth of a population over time.
