Question about PWM inverter output
In summary, the amplitude of the output of a PWM inverter depends on how long the sinusoidal modulating signal is greater than the carrier. If you subtract the output (scaled down) from a reference signal in order to get some error and use this error as the modulating signal then having a reference higher than your measured output will create a larger modulating signal and it will bring you to around equilibrium... unless there's an overshoot. If at any point, your measured voltage is greater than your reference signal, the error will increase, thus increasing your measured output voltage thus further increasing the error.
Dextrine
102
So, this is what I know so far, please correct me if I'm wrong.
The amplitude of the output of a PWM inverter depends on how long the sinusoidal modulating signal is greater than the carrier.
If you subtract the output (scaled down) from a reference signal in order to get some error and use this error as the modulating signal then having a reference higher than your measured output will create a larger modulating signal and it will bring you to around equilibrium... unless there's an overshootif at any point, your measured voltage is greater than your reference signal, the error will increase, thus increasing your measured output voltage thus further increasing the error.
I'm pretty sure I must be missing something here, but from what I can see, if your measured voltage is greater than your reference, your error will just increase forever. Where is my logic breaking down?
Thanks in advance.
Are you missing that the error signal can be plus or minus. Your description sounds like any genetic negative feedback controller.
Try putting some numbers in...
Lets say the reference is 5V and the output 4V.
Subtract the output from the reference and you get 5-4 = 1V which is POSITIVE so the output will be increased. All fine so far..
No that's incorrect.
Lets say the reference is still 5V but the output is 6V.
Subtract the output from the reference and you get 5-6 = -1V which is NEGATIVE so the output will be reduced not increased.
Modulation Signal = Reference + ( Reference - Measured).
What do you recommend reading to better understand controller design specifically for PWM inverters? So far, what I've found online seem to assume the reader to know a lot of details and I would like as in depth a description as I can get.
This is control theory - and it applies directly and cleanly to Power Electronics.
Wiki
Do not over-think it... when you try to consider it all at once then it is hard to separate the theory ( control) from the PWM concept, then from the code / microcontroller (the tool).
Thanks for the words of encouragement. This is definitely very interesting stuff though pretty hard.
So, I have some more questions I'm hoping someone can answer:
Why would you need a current control loop AND a voltage control loop in a PWM inverter? By controlling the voltage across the output filter (simple LC), aren't you by default controlling the current?
Why wouldn't you be able to just have a voltage output sensor, compare the value it reads with your reference, send that signal as your modulating signal which will change the PWM accordingly?
Or, why couldn't you do the same thing with just a current sensor since controlling the current across the capacitor will automatically be controlling the output voltage?
So it looks like you CAN do what I proposed, as is seen on this paper http://www.ijsr.net/archive/v3i8/MDIwMTU5MjE=.pdf
now, my question changes to, what would the block diagram for this look like, I keep getting that I will need to also know output current but in the picture the only sensor is output voltage.
Related to Question about PWM inverter output
1. What is PWM inverter output?
PWM (Pulse Width Modulation) inverter output is a type of AC (Alternating Current) output that uses a combination of high-frequency switching and pulse width modulation to convert DC (Direct Current) power into AC power. This output is commonly used in power electronics and motor control applications.
2. How does PWM inverter output work?
PWM inverter output works by using a high-frequency switching circuit to chop the DC input into pulses. The width of these pulses is then modulated to achieve the desired output voltage and frequency. This process creates a simulated AC wave with varying voltage levels, which can be used to power AC devices.
3. What are the advantages of PWM inverter output?
The main advantage of PWM inverter output is its ability to produce a highly stable and precise AC output with minimal distortion. It also allows for efficient use of power, reducing energy waste. Additionally, PWM inverters are compact, lightweight, and have a longer lifespan compared to other types of inverters.
4. What are the applications of PWM inverter output?
PWM inverter output has a wide range of applications, including renewable energy systems, electric vehicles, uninterruptible power supplies, and motor control in industrial and commercial settings. It is also commonly used in household appliances such as refrigerators, air conditioners, and washing machines.
5. What are the potential drawbacks of PWM inverter output?
One potential drawback of PWM inverter output is the generation of high-frequency switching noise, which can interfere with other electronic devices. It also requires complex control circuitry, making it more expensive compared to other types of inverters. Additionally, PWM inverters may not be suitable for high-power applications due to their limited power handling capacity.
  • Electrical Engineering
9K
19K
