Question about quantum superposition in CMB photons
In summary, the CMB photons reaching our telescopes have traveled for over 13 billion years without interacting, resulting in a wavefunction that spreads and encompasses many possible states in superposition. This means that by the time they finally interact, there is a significant chance of an unlikely state becoming the actual outcome of the collapse. However, this reasoning is incomplete without taking into account the effects of expansion and temperature on the distribution of photons, which has been accounted for in the calculation that matches our observations. Therefore, the CMB shows no significant distortions from its original state.
Gerinski
323
Hi,
CMB photons reaching our telescopes have traveled for over 13 billion years without interacting with anything.
If I understand correctly, from the event of the photon emission, its wavefunction gradually spreads, encompassing more and more possible states for the photon, coexisting in superposition, until the photon will interact with another quantum (the detector in our telescope). So for example, the longer the photon travels the bigger the chances that it will collapse in a more improbable state. If the photon has a certain momentum and it interacts very shortly after its emission, most chances are that it will collapse at a location in the precise direction of its momentum. But the longer it travels undisturbed, the possible states diverge and the more chances that it will collapse at a location a bit farther from the original momentum line.
If this is the case, after 13 billion years the wavefunction of the CMB photons should have spread enormously and contain many possible different states (i.e. locations where the photon may collapse) in the superposition, including many which would have seemed very improbable at much earlier epochs during the photon's travel.
So by the time they finally interact, there should be significant chances of an unlikely state to become the actual outcome of the collapse.
Following this reasoning it seems that we should expect the CMB to show significant "distortions", its photons collapsing at relatively unlikely locations and not in the line of the momentum they were originally emitted.
Is this reasoning more or less correct?
Thanks
Word arguments are troublesome in such situations. You really need some math to throw around to get a more exact feel for what you are doing. Phrases like "should have spread enormously" are potentially misleading.
You need to write an equation for what really happens to a photon as it travels along in an expanding geometry background. And then, what happens to the probability of observing various possible momentum values. And once you have that, you need to think about what happens to a distribution of photons that start out at a cosmologically high temperature (round about the point the universe became transparent) and what that distribution would look like now.
What you should find is, the distribution now looks like a thermal distribution at about 3 K. If you can demonstrate something different then you have a remarkable result.
The reasoning is completely wrong or completely right depending on how what you mean by "distortion". Anyway, all the "distortions" that you expect from the time evolution from the time the photon is created to now when the collapse is measured are already included in the calculation that matches what we observe.
Related to Question about quantum superposition in CMB photons
1. What is quantum superposition in CMB photons?
Quantum superposition is a principle in quantum mechanics where a quantum system can exist in multiple states or positions simultaneously. In the case of CMB photons, this means that they can exist in a superposition of different energy levels, leading to a range of possible frequencies that can be observed.
2. How does quantum superposition affect CMB photon observations?
Quantum superposition can affect CMB photon observations by causing the photons to have a spread of energies, rather than a single, well-defined energy level. This can impact the accuracy of measurements and predictions made using CMB data.
3. Can quantum superposition explain the anomalies in CMB data?
There is currently no evidence to suggest that quantum superposition can explain the anomalies in CMB data. While it is a fundamental principle in quantum mechanics, it is not yet fully understood how it may apply to the behavior of CMB photons.
4. Is quantum superposition the only factor that affects CMB photon observations?
No, there are many factors that can affect CMB photon observations, including gravitational lensing, cosmic variance, and instrumental noise. Quantum superposition is just one potential factor that may contribute to the complexities of CMB data.
5. How are scientists studying quantum superposition in CMB photons?
Scientists are studying quantum superposition in CMB photons through various experiments and observations. This includes analyzing CMB data using different statistical methods, conducting laboratory experiments with quantum systems, and developing theoretical models to better understand the behavior of CMB photons.
