Question about real world examples of 2.7 megajoules
  • B
  • Thread starter ArmChairPhysicist
  • Tags
    Real world
In summary, Space engineers has a cannon that can fire a projectile at high speeds. The physics are how much energy the cannon can deliver in the form of kinetic energy. After building a small cannon for testing and dusting off my physics textbook, I came up with these variables. The mass of the projectile, acceleration due to the gravitational forces I've enslaved, and total distance of acceleration are all variables that need to be considered when calculating the final velocity of the projectile. After a bit more math, I found that the final velocity of the projectile is 542.4942396 m/s. If needed, I can put a link to the thread I found my velocity from acceleration and distance work on. Finally, I used the lovely 1/
ArmChairPhysicist
45
Recently I decided to combine three of my favorite things, physics, machines that propel things, and videogames.
The game in question: Space engineers.
Machine in question: A device of my own creation that abuses the marvel of artificial gravity to accelerate a projectile at high speeds.
The physics? How much energy can one of my cannons deliver in the form of kinetic energy.
After building a small cannon for testing and dusting off my physics textbook I came up with these variables.
Mass of the projectile: 20 tons or 18143.695 kilograms.
Acceleration due to the gravitational forces I've enslaved: 1177.20 m/s^2
Total distance of acceleration: 125 meters.
After a bit more math I found that the final velocity of the slightly unrealistic 20 ton shell is 542.4942396 m/s.
If needed I can put a link to the thread I found my velocity from acceleration and distance work on.
Now using the lovely 1/2mv^2 I came to a kinetic energy of 2,669,844,719 j, or 2.7 mj.
Now here is my problem. My mathematically inclined brain says that's a lot. But physics brain is saying that's not all that much energy.
How much energy is 2.7 megajoules?
Is there any good real world examples of something with this kind of energy?
Many thanks in advance.
More information about the device that wasn't pertinent to the question. What I constructed today is an infinitesimal launcher compared to some of my builds. Today's only utilized 120 generators in game. My biggest have used many thousands of generators, each outputting 9.81m/s^2 acceleration within their fields. One of these days I'll build one of these larger ones and do the math on their kinetic energy outputs. But this becomes tricky due to uneven acceleration fields along the "barrel" due to overlap of thousands of generators.
Such energies are often compared to "tons of TNT": (1 kg TNT = 4 MJ)
https://en.wikipedia.org/wiki/TNT_equivalent
The meteor of Chelyabinsk had more than 500 kilotons.
I think you mean 2.7 Gigajoules. 2.7 Megajoules isn't that much energy - it's about the amount of food energy in a cheeseburger (600 calories). For reference, 1 Kilowatt-Hour is 3.6 Megajoules.
Likes hutchphd
Evidently all of my school work has leaked out of my head while I slept, there was my mistake. I apparently can't differentiate between 2.7 million and 2.7 billion
And to ask again, 2.7 gigajoules? Just how much better is that?
You could calculate how much water that energy can heat from room temperature to boiling point, by using the heat capacity ##C_{H_2 O} \approx 4000## JK-1kg-1.
2.7Mj is energy of 1.4 tonne car speeding 150km/h. You have 2.7Gj so it's eneegy of about 1000 cars speeding fast on highway.
or Wimpy says 1000 cheeseburgers viz
(Of course this is 600kcal in physics calories)
Likes sophiecentaur
What an odd necropost.
But a food calorie is a kilocalorie. I stick of dynamite = 1 stick of butter = 1 MJ.
Likes russ_watters and Bystander
Didn't see that it was necro (blinded by the cheese)......
It suddenly strikes me that Nuclear Weapon Yield might sound less scary if reported in butter equivalent energy. I know I would rest easier.
A kiloton of butter would probably give you a heart attack too -just for a different reason.
I realize that part of my motivation for this unit of destructive power can be traced directly to the existence of the "The Butter Battle Book" by Dr. Seuss.
I presume it is still allowed in school libraries in some places
  • Haha
Likes russ_watters
Or 1 Fat Man = 88 million sticks of butter. Oof.
  • Haha
Likes Vanadium 50, berkeman and hutchphd
russ_watters said:
Fat Man
Called that for a reason.
  • Haha
Likes hutchphd
Let's crank it up a notch.
1 foe = 10^44 J = 10^38 MJ = 10^34 tons of TNT = 10^28 megatons of TNT.
1 kilocalorie = 4,184 joules and a 113 g stick of butter has 810 kilocalories, or 3.389 MJ.
So 1 foe = roughly 3x10^37 sticks of butter.
I propose a new unit: 1 foebutter (fb) = 10^44 grams of butter = 4.728x10^43 MJ of energy.
Inconveniently, the megafoebutter is shortened to Mfb, possible causing confusion with @mfb. By mass, one mfb is much less than one Mfb, but I suspect the former has a greater words per minute (WPM) if their post count is any indication.
  • Haha
Likes berkeman
I've created a monster. 👾
  • Haha
Likes berkeman, hutchphd and Drakkith
FAQ: Question about real world examples of 2.7 megajoules
1. What is a megajoule?
A megajoule (MJ) is a unit of measurement for energy, equivalent to one million joules. It is often used to measure the energy content of fuels or the amount of work done by a machine.
2. Can you provide a real-world example of 2.7 megajoules?
2.7 megajoules could be equivalent to the energy needed to power a 100-watt light bulb for 27,000 seconds, or about 7.5 hours. It could also power a microwave for 13 minutes or a hairdryer for 5 minutes.
3. How does 2.7 megajoules compare to other units of energy measurement?
2.7 megajoules is equivalent to 2,700 kilojoules, 0.0027 gigajoules, or 0.000027 terajoules. It is also equal to 0.239 kilowatt-hours (kWh) or 239 watt-hours (Wh).
4. Is 2.7 megajoules a large amount of energy?
It depends on the context. Compared to the energy used in everyday household appliances, 2.7 megajoules may seem like a large amount. However, in the context of industrial or scientific processes, it may be considered a relatively small amount of energy.
5. How is 2.7 megajoules used in scientific research?
In scientific research, 2.7 megajoules may be used to measure the energy released in chemical reactions or to power experiments and equipment. It may also be used to calculate the energy efficiency of systems or to determine the energy requirements for certain processes.
