Question about repeated measures Anova and multiple regression
However, it is important to carefully consider which variables to transform and which transformations to use, as this can affect the interpretation of the results.
miau
This is for my coursework. I have two problems. The first one.
I have two time messures. Before and after a scheme was introduced.I have to answer a question if it made a statistically significant difference or not. And also as it was introduced in 3 places I need to know if it worked equally well in all of them.
Two time meassures are on the interval scale, place is a categorical variable place 1, place 2 and place 3.
The major problem is that data is not normally distributed (and it is impossible to fix that, I tried various data transformations), so my question is which non-parametric equivalent test should I use?
To be honest I can't decide if it is a one way repeated measures anova or mixed factors repeated measures anova as I am still new at this topic. I just keep changing my mind and performing these tests again and again (parametric versions, although I am aware I should go with non-parametric test)
As I mentioned before I tried tranforming the data in order to make the distribution normal but I have never (so far ) seen anything so far from the normal distribution pattern and nothing is working.
Another question:
I have two IV and 1 DV (all are interval) and I need to build a multiple regression model to be able to predict DV from these two IVs . However, residuals are not normally distributed also there is heteroscedascity.
How can I fix this, should I use general linear model (via SPSS) to build my equation instead? How? So far I only dealt with data which met the assumptions.
I need to use multiple regression, also to find which of the two is better predictor
I tried data transformations but how do I know which variable to transform and which transformation to use? Also I tried using general linear model but I am not sure if that is aprropriate.
I didn't give much details because I don't think I can do that. I hope the information I provided is enough to understand the types of problems I am facing.
Thank you.
The solution to your first problem is to use a non-parametric test, such as the Kruskal-Wallis test, to determine if there is a statistically significant difference between the before and after measurements. This test can also be used to compare the difference in performance across the three places. For the second problem, one solution is to use the Generalized Linear Model (GLM) instead of the multiple regression. GLM allows for the testing of non-linear relationships and can be used to account for heteroscedascity and non-normal residuals. You can also try using polynomial terms or transformations of the independent variables to reduce heteroscedascity and make the residuals more normally distributed.
FAQ: Question about repeated measures Anova and multiple regression
What is the difference between repeated measures ANOVA and multiple regression?
Repeated measures ANOVA is a statistical test used to analyze the effects of one independent variable on a dependent variable measured at multiple time points or under multiple conditions. Multiple regression, on the other hand, is used to analyze the relationship between multiple independent variables and a single dependent variable.
When should I use repeated measures ANOVA and when should I use multiple regression?
Repeated measures ANOVA is typically used when the independent variable is categorical and the dependent variable is continuous. Multiple regression is used when the independent variables are continuous and the dependent variable is also continuous. However, there can be some overlap in the use of these tests depending on the research question and data.
How do I interpret the results of repeated measures ANOVA and multiple regression?
In repeated measures ANOVA, the main output to look at is the F-statistic, which indicates whether there is a significant difference between the means of the groups. In multiple regression, the main output to look at is the regression coefficients, which indicate the strength and direction of the relationship between the independent variables and the dependent variable.
Can I use both repeated measures ANOVA and multiple regression in the same study?
Yes, it is possible to use both tests in the same study. For example, if you have one categorical independent variable and several continuous independent variables, you could use repeated measures ANOVA to analyze the effects of the categorical variable and multiple regression to analyze the relationship between the continuous variables and the dependent variable.
What are some common assumptions of repeated measures ANOVA and multiple regression?
Some common assumptions of repeated measures ANOVA include normality of the dependent variable within each group, homogeneity of variances, and sphericity. For multiple regression, some common assumptions include linearity, independence of errors, and normality of errors. It is important to check these assumptions before interpreting the results of these tests.
