Question about resolving forces
In summary, when the mast is hinged at O to the deck, it rotates in the vertical plane. At points A and B on the deck, small smooth rings are fixed and threads from C are passed through these rings. Forces of P Newtons and Q Newtons are applied to the ends of the threads, and the mast remains in equilibrium if Q=10.
parsesnip
On a model ship, the mast OC has length 50 cm and weight 20 Newtons. The mast is hinged to the deck at O, so that it can rotate in the vertical plane of the ship. Small smooth rings are fixed at points A and B on the deck in this plane such that AO=OB=50 cm. Threads from C are passed through these rings, and held at their ends by two children who exert forces of P Newtons and Q Newtons respectively. If Q = 10, calculate the value of P needed to hold the mast in equilibrium at 40° to the horizontal deck.
2. The attempt at a solution
I tried finding a simultaneous equation by resolving the forces horizontally and vertically, but I was unable to do so as there are 6 different forces (P,Q,tension in AC,tension in BC, tension in OC, weight of OC) and the angles between P and the deck and Q and the deck are unknown (I found the angles between AC and the deck and CB and the deck as 20° and 70° respectively (or it could be the other way round?).).
Some of those are easily seen to be the same, if there is no friction in the rings.
This also makes some angles irrelevant.
Likes parsesnip
Ok. I think that |P| = |tension in AC| and |Q| = |tension in BC| (because the length of the strings has to stay equal). Then I get the equations:
Psinθ-Psin20°+Tsin40°-20-10sin70°+10sinφ=0
Pcosθ+Pcos20°-Τcos40°-10cos70°-10cosφ=0.
I think maybe Tsin40°=20?
Yes, but I would have said that it was because otherwise the rope would slide through the ring.
What are θ and φ, and how do you get those equations?
θ is the angle between P and the horizontal and φ is the angle between Q and the horizontal.
I got those equations by resolving the forces vertically and horziontally (as the system is in equilibrium so net force = 0)
You are ignoring the forces the rings exert on the ropes.
Just stick with the fact that the tension doesn't change as the rope passes through a ring and consider the forces on the mast.
Likes parsesnip
So the forces acting on the mast are the tensions of AC, AB and AO and the weight.
The equations are:
Pcos20=10cos70+Tcos40
Tsin40=20+10sin70+Psin20
P=72.3 N?
Did you mean that?
What is T and how do you get this equation? What direction are you resolving in?
(Do not assume the force the deck exerts on the mast at O acts along the mast.)
Related to Question about resolving forces
What is the definition of resolving forces?
Resolving forces is the process of breaking down a single force into its components in order to determine the individual effects of each force.
Why is it important to resolve forces?
Resolving forces is important because it allows us to understand the individual contributions of multiple forces acting on an object. This helps us analyze and predict the motion of an object accurately.
How do you resolve forces?
To resolve forces, you need to use trigonometric functions such as sine, cosine, and tangent to determine the horizontal and vertical components of a force. These components can then be combined using vector addition to find the net force.
Can forces be resolved in any direction?
Yes, forces can be resolved in any direction as long as you have the necessary information such as the magnitude and direction of the original force.
What are some real-life applications of resolving forces?
Resolving forces is used in various fields such as engineering, physics, and sports. Some examples include calculating the forces acting on a bridge, analyzing the motion of a projectile, and determining the forces involved in a game of billiards.
