MHB Question about roots/synthetic division
  • Thread starter Thread starter Madds
    Division
The original polynomial is identified as 5x^3 + 6x^2 + 7x + 6, derived from the coefficients used in synthetic division. The root of the polynomial is -1, confirmed by the fact that substituting -1 into the polynomial results in a value of zero. This indicates that (x + 1) is a factor of the polynomial. Synthetic division simplifies the process of finding roots by using coefficients and the value of the root to determine the polynomial's behavior. Understanding synthetic division is crucial for accurately identifying roots and factors of polynomials.
Madds
According to the synthetic division done below, what was the original polynomial and what number do we know is a root of that polynomial? Explain how you know to receive full points.
I know what the polynomial is, but I thought the root of this polynomial would be 1 but it's actually -1 could somebody explain why?
Mathematics news on Phys.org
When doing synthetic division, the actual root $r$ or zero of the polynomial is put out to the left. Thus we know:
$$f(r)=0$$
And the polynomial function will contain the factor $(x-r)$. This might be why you felt the number needed to be negated?
Your question is puzzling. Are you clear on what "synthetic division" is? It is a quick way of dividing a polynomial by x- a for some value of a. Specifically, we write just the coefficients of the polynomial (here that is "5 6 7 6" which tells us that the original polynomial was [math]5x^3+ 6x^2+ 7x+ 6[/math]. The number we are "dividing" by is a= -1. In general, if we divide a polynomial, P(x), by x- a, the remainder is P(a).
The synthetic division here, shows that when x, in this polynomial, is set to -1, the value of the polynomial. is 0. That means that x= -1 is a root.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
