Question about space junk in orbit
In summary, the conversation discusses the reasons why small pieces of space junk can pose a threat to the International Space Station. It is explained that different pieces of debris may be moving at different velocities due to their varying directions and orbits. The conversation also touches on the issue of collisions and how they can result in objects with high energy and elliptical orbits. It is mentioned that the ISS operates in a low orbit due to resupply constraints, but it is also beneficial because objects in this orbit will eventually slow down and burn up in the atmosphere, reducing the amount of space junk. However, it is noted that some objects, such as the Vanguard 1, can remain in orbit for long periods of time despite losing power.
Pollywoggy
53
I did not know where else to post this question but put it here since it is more related to mechanics than to astronomy.
I am curious as to why small bits of space junk (bolts for example) are traveling so fast around Earth that they could poke holes in the International Space Station. Are different pieces of junk moving around Earth at different velocities even though they are located in similar (or the same) orbit? When I read news stories about space junk, the same number is mentioned as the speed of orbiting debris in space, approximately 17,000 mi/hr.
Is it because although the objects are the same distance away from the surface of Earth, they might be traveling in different directions?
If they are in the same orbit then there is no problem, they are moving at huge speeds (nearer 17,000 mph - your value is about 10% c)
And since most spacecraft are launched west-east to get a boost from the Earth's spin - most are moving in the same direction.
The problem is in low Earth orbit - there are good reasons to have satelites in a polar orbit.
So like a busy intersection you have spacecraft going west-east and others going north-south. Unfortunately many of these spacecraft are from California and so ignore stop signs.
oops I meant 17,000 mi/hr not second.
Thanks for the reply, it makes sense that the reason the small objects are a hazard to the space station is that not all the objects are traveling in the same direction and the orbits cross one another.
The space station and other low orbit objects are still in the outer fringes of the atmoshpere, so without an occasional boost, they will even eventually slow down and hopefully burn up in the upper atmosphere. The issue of collisions would be stuff with a higher energy but somewhat elliptical orbit. I'm not sure how space junk would end up with an elliptical orbit enough to result in large speed differences if there is a collision.
Most pieces of space junk are very small and thus will have a fairly small ballistic coefficients. Orbits of things with a small ballistic coefficient circularize rather quickly. The issue of collisions is not so much eccentricity as it is inclination (which can be anywhere from -20 degrees or so to 100 degrees) and right ascension (pretty much uniformly distributed over 0 to 2*pi).
For example, suppose two orbiting objects collide. If both are in circular orbits at the same LEO altitude, both have a 30 degree inclination, but the right ascensions of ascending node differ by 180 degrees, the relative velocity at collision will be about 17,000 mph (2*sin(30 degrees)*17,000 mph).
But the idea behind the low orbit of the space station within the outer fringe of the atmosphere is that any old space junk at the same orbital energy, especially if circular, should have been slowed down by the atmosphere, burnt up, and no longer a threat.
Where ever did you get that idea? The only reason the ISS operates in as low an orbit as it does is because of resupply constraints. The Soyuz spacecraft can only get to 425 km or so.
As the ISS constantly loses altitude because of slight atmospheric drag, it needs to be boosted to a higher altitude several times each year.
From wiki:
ISS_altitude_control.htm
Skylab did ultimately slow down and burn up.
Yes, but correlation does not equal causation. That isn't why the ISS is in a low orbit, as you seem to intimate.
True, energy is the main reason, but it is a beneficial side of effect of low Earth orbits in the atmospheric fringes. If the object loses power, it eventually slows down and burns up, a method of self disposal.
On the other hand Vangard 1, launched in March 17 1958 (happy belated 50th birthday), lost communications in 1964, but it's still up there orbiting for over 50 years now. Expected life time is 240 years.
http://en.wikipedia.org/wiki/Vanguard_1
Yeah! I mean those NASA guys would never have taken the LEO advantages for space junk into consideration when they designed ISS's shape and shielding and so forth. I mean after all, they're not rocket scien... uh, nevermind. :smile:
The ISS is in a terrible orbit because of political compromises - it is at a very high inclination so it can be reached from Baikanur which limits the payoad of a shuttle trying to reach it.
One thing about some space junk like bolts is they have a very high density and low surface area, which reduces the average effect of atmospheric drag, compared to the ISS which is basically a big sailboat.
... and a higher altitude further limits the Shuttle's payload capacity to the ISS. The ISS is currently in a fairly low altitude because
  • It currently can be fly at a lower altitude due to reduced atmospheric drag (thanks extended solar minimum!)
  • It currently needs to fly at a lower altitude due to increased radiation hazard at higher altitudes (once again thanks to the extended solar minimum) and
  • Doing so enables more cargo to be sent to the ISS (more below).
The "Final Report of the International Space Station Independent Safety Task Force", http://www.nasa.gov/pdf/170368main_IIST_ Final Report.pdf, identifies micrometeoroid and orbital debris impact with the ISS as a "high risk to abandoning the ISS or to the loss of the ISS vehicle and/or crew." Did they recommend operating the ISS at a lower altitude because of this risk? No. They recommended adding shielding and negotiating with Russia (who think the US are a bunch of namby-pambies in this regard).
The Safety Task Force identified several other risks, including logistics. While the task force did not recommend that the ISS operate at a lower altitude, doing so certainly does help solve the logistics shortfall. An additional 100 pounds of cargo can be added to the Shuttle for every nautical mile of reduced ISS altitude. The Soyuz spacecraft similarly benefit from reduced ISS altitude.
The upper altitude limit of the ISS, ~250 nautical miles, has nothing to do with space debris. Logistics and radiation hazard are the sole drivers.
FAQ: Question about space junk in orbit
1. What is space junk?
Space junk refers to any man-made debris or objects in orbit around the Earth that are no longer functional. This can include old satellites, rocket fragments, and other pieces of debris.
2. How does space junk affect our planet?
Space junk poses a potential threat to both human-made and natural objects in space. It can damage functional satellites and spacecraft, and even collide with other pieces of space debris, creating more debris in the process. This can disrupt communication, navigation, and other important functions on Earth.
3. How much space junk is currently in orbit?
It is estimated that there are over 128 million pieces of space junk larger than 1 millimeter in orbit around the Earth. This number continues to increase as more objects are launched into space and collisions occur.
4. What is being done to clean up space junk?
Several organizations, including NASA and the European Space Agency, are actively working on solutions to remove space junk from orbit. Some proposed methods include using nets, harpoons, or lasers to capture and remove debris.
5. Can space junk fall to Earth?
Yes, space junk can fall to Earth if it is in a low enough orbit and experiences enough atmospheric drag. Most objects will burn up in the atmosphere before reaching the Earth's surface, but some larger pieces may survive and potentially cause damage upon impact.
