Question about spectral lines of stars?
In summary, the observed spectral lines in starlight are caused by a combination of factors including temperature, scattering, and geometric effects. The most common type of line is the photospheric absorption line, which results from light passing through cooler gas in the visible layer of the star. However, there are also other types of lines in different parts of the solar spectrum, such as emission lines from ionized helium in the corona. The photosphere also produces its own spectral lines, including both absorption and emission lines from elements like helium.
21joanna12
126
I can't seem to find an answer to this quick question: which part of the star causes the observed spectral lines? As I understand, the photosphere is the deepest visible layer of the star, and then light passes through the chromosphere and the corona. I would think that both the chromosphere and corona would cause spectral lines, but at the same time I have read that both of these layers have a higher temperature than the photosphere, and spectral lines can only be formed if the light passes through a cooler gas... Would the photosphere be producing its own spectral lines too?
Thank you in advance :)
Astronomy news on Phys.org
http://www.astro.washington.edu/users/anamunn/Astro101/Project1/stellar_spectroscopy_introduction.html
You'll notice that the spectra of starlight comes as a continuous "rainbow" with lines missing ... the continuous rainbow comes from everywhere but specifically deep int he star. This light has to pass through the outer layers, which absorb some wavelengths, giving the dark lines.
There is no requirement for the gas to be cooler, any time a continuum passes through low density gas, spectral lines will be superimposed on that continuum because the low density gas only interacts with the light at certain wavelengths. There are many ways of getting either absorption or emission lines, some involving temperature, some involving scattering, and some involving geometric effects, and the Sun involves a lot of these phenomena. But the most common one is the photospheric absorption line-- that's the one that involves light passing through cooler gas, because the temperature in the photosphere drops as you go out from the center.
Yes, those are mostly the lines you see. The "photosphere" is not really all one place, it's not an infinitely thin spherical shell. The photosphere is best defined as simply the gas that is visible to us and is undergoing an equilibrium between the rate it absorbs light from below, and the rate it emits light into deep space. The fact that light is diffusing through it causes its temperature to fall as you go out, and that is what causes those absorption lines, but there are also other kinds of lines in other parts of the solar spectrum-- like chromospheric and coronal lines.
Indeed, the element named for the Sun, helium, was first discovered by looking at emission from ionized helium in the solar corona during a solar eclipse. That light would be seen in emission simply because you are waiting for the Moon to block out the solar continuum, and you see the line from outside the disk of the Sun against no continuum background. Otherwise it would be swamped by the brightness of the Sun. I believe we can now also see absorption lines from neutral helium in the photosphere, and if so, that provides an example of both types of lines from the same element in the Sun in different situations.
Likes 21joanna12
Related to Question about spectral lines of stars?
1. What are spectral lines of stars?
Spectral lines of stars are dark or bright lines that appear in a star's spectrum due to the absorption or emission of light by certain elements in the star's atmosphere. These lines can provide valuable information about a star's chemical composition, temperature, and other physical properties.
2. How are spectral lines of stars formed?
Spectral lines are formed when light from a star passes through its atmosphere and interacts with the atoms and molecules present. Each element absorbs or emits light at specific wavelengths, creating dark or bright lines in the spectrum. This process is known as spectroscopy.
3. What can we learn from spectral lines of stars?
By studying the spectral lines of stars, scientists can determine the chemical composition of a star, its temperature, density, and motion. This information can help us understand the evolution of stars and their role in the universe.
4. How do scientists use spectral lines to classify stars?
Scientists use spectral lines as a tool to classify stars based on their chemical composition. By comparing the intensity and positions of different spectral lines, they can determine the elements present in a star's atmosphere and assign it to a specific spectral type.
5. Do all stars have the same spectral lines?
No, each star's spectral lines are unique and depend on its chemical composition and other physical properties. This is why scientists can use spectral lines to identify and distinguish between different stars.
  • Astronomy and Astrophysics
