Question about Stark interference
In summary, the conversation discusses a question about a paper that claims to use points A and F for their experiment. The question asks how an electric field in the z direction can connect two states of different m_N values, given that the dipole moment operator doesn't interact with electron or nuclear spins. The conversation also includes equations and references to a paper that discusses a mixture of quantum numbers allowing for a weak, higher-order stark effect.
BillKet
313
29
Hello! I have a question about this paper (@Twigg ?). They claim towards the end of the second page that they use points A and F for their experiment. But for example, at point A the molecular rotation quantum numbers are ##|N=0,m_N=0>## and ##|N=1,m_N=1>##. However, in their experiment the electric field is in the z-direction, which is the direction of the magnetic field, too, which defines the ##m_N##. So if that is the case (and given that the dipole moment operator doesn't interact with the electron or nuclear spins), how can an electric field in the z direction connect 2 states of different ##m_N##? Am I missing something?
Based on my math we should have this:
$$<N=0,m_N=0|\vec{d}\cdot\vec{E}|N=1,m_N=1> = <N=0,m_N=0|d\hat{n}\cdot\vec{E}|N=1,m_N=1>$$
where E is the electric field and ##\hat{n}## is the internuclear axis direction (defined in the frame of the molecule). In general we have:
$$\hat{n} = \sin\theta\cos\phi \hat{x} + \sin\theta\sin\phi \hat{y} + \cos\theta\hat{z}$$
when expressing ##\hat{n}## in the lab frame. From here we get:
$$<N=0,m_N=0|\vec{d}\cdot\vec{E}|N=1,m_N=1> = E_z <N=0,m_N=0|\cos\theta|N=1,m_N=1> $$
We also have that:
$$\cos\theta \propto Y_1^0$$
where ##Y_1^0## is a spherical harmonic and:
$$|N,m_N> \propto Y_N^{m_N}$$
so the above term becomes:
$$<N=0,m_N=0|\vec{d}\cdot\vec{E}|N=1,m_N=1> = E_z \int(Y_0^0\times Y_1^0 \times Y_1^1)$$
where the integral is over ##\theta## and ##\phi##. But that integral is zero (which is a long way of saying that the signed sum of ##m_N## values appearing in the spherical harmonics of that integral is not zero).
Sorry for the really slow reply!
Check out this paper: https://arxiv.org/abs/0708.2925
Specifically, the paragraph near the bottom of the left column on page 2 that starts "We calculate C...".
In short, there is some mixture of quantum numbers in either parity state that allows a weak, higher-order stark effect.
Hope that helps!
Likes BillKet and DrClaude
FAQ: Question about Stark interference
What is Stark interference?
Stark interference is an effect observed in atomic and molecular systems when an external electric field causes a splitting of energy levels, resulting in the interference of different energy states.
How does Stark interference occur?
Stark interference occurs when an external electric field interacts with the charged particles in an atom or molecule, causing a shift in the energy levels. This shift can lead to the overlapping and interference of different energy states.
What is the significance of Stark interference in scientific research?
Stark interference is important in understanding the behavior of atoms and molecules in the presence of external electric fields. It has applications in various fields such as spectroscopy, quantum computing, and laser technology.
Can Stark interference be controlled or manipulated?
Yes, Stark interference can be controlled and manipulated by changing the strength and direction of the external electric field. This allows for precise control over the energy levels and can be useful in experiments and applications.
Are there any real-world examples of Stark interference?
Yes, Stark interference has been observed in various experiments, such as the splitting of spectral lines in atoms and molecules, the Zeeman effect, and the Stark effect in Rydberg atoms. It also plays a role in the operation of devices like lasers and microwave generators.
